error: sycl::_V1::exception wrong loction
lzy
I have met a problem, the error code is:
There is an unhandled exception at 0x00007FFBDB684C3C (located in two_d.exe): Microsoft C++Exception: syncl::V1::exception, located at memory location 0x000000605F988C00.
My GPU version: Intel(R) Iris(R) Xe Graphics
My Visual Studio Version: Microsoft Visual Studio Professional 2022 17.3.6
BTW, I do can run oneapi dpc++ example.
Thanks for your help.
Best
My code is:
#include <vector>
#include <iostream>
#include <CL/sycl.hpp>
using namespace cl::sycl;
std::vector<std::vector<double>> filter2d(const std::vector<double>& b, double a, const std::vector<std::vector<double>>& x) {
int rows = x.size();
int cols = x[0].size();
std::vector<std::vector<double>> y(x.size(), std::vector<double>(x[0].size()));
auto z = b.size();
std::vector<double> flat_y(rows * cols);
std::vector<double> flat_x(rows * cols);
for (int i = 0; i < rows; i++)
for (int j = 0; j < cols; j++)
flat_x[i * cols + j] = x[i][j];
flat_y[i * cols + j] = y[i][j];
sycl::buffer<double, 1> b_buffer(b.data(), range<1>(rows));
sycl::buffer<double, 2> x_buffer(flat_x.data(), range<2>(rows, cols));
sycl::buffer<double, 2> y_buffer(flat_y.data(), range<2>(rows, cols));
sycl::queue q(sycl::gpu_selector_v);
std::cout << "Device name: " << q.get_device().get_info<sycl::info::device::name>();
q.submit([&](sycl::handler& h) {
sycl::accessor x_acc(x_buffer, h);
sycl::accessor y_acc(y_buffer, h);
sycl::accessor b_acc(b_buffer, h);
auto out = sycl::stream(512, 256, h);
h.parallel_for(sycl::range{ static_cast<size_t>(rows), static_cast<size_t>(cols) }, [=](sycl::id<2> idx) {
int i = idx[0];
int j = idx[1];
y_acc[i][j] = 0.0;
for (int k = 0; k < z; k++)
if (i - k >= 0)
y_acc[i][j] = y_acc[i][j] + b_acc[k] * x_acc[(i - k)][j];
y_acc[i][j] = y_acc[i][j] / a;
}).wait();
sycl::host_accessor y_h(y_buffer);
for (int i = 0; i < rows; i++) {
for (int j = 0; j < cols; j++) {
y[i][j] = y_h[i][j];
return y;
int main()
std::vector<double> b = { 1.0, 2.0, 1.0 };
double a = 1.0;
std::vector<std::vector<double>> x = {
{ 1.0, 2.0, 3.0 },
{ 4.0, 5.0, 6.0 },
{ 7.0, 8.0, 9.0 }
auto y = filter2d(b, a, x);
std::cout << "\n";
for (const auto& row : y) {
for (const auto& val : row) {
std::cout << val << " ";
std::cout << "\n";
return 0;
lzy
I can run this code on another PC with GPU: Intel(R) UHD Graphics 630, Visual Studio version: Microsoft Visual Studio Community 2022 17.6.5。
lzy
but on Intel(R) UHD Graphics 730. it turns out that it has the same problem as on Iris.
NoorjahanSk_Intel
We have reported this issue to the concerned development team. They are looking into your issue.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Iris Xe Graphics doesn't support double precision.
We request you to change double to float data type so that the code works without any errors.
We will get back to you regarding Intel(R) UHD Graphics 730.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thanks for your patience.
Intel(R) UHD Graphics 730 also does not have native support for double precision
So we suggest you to change the double data type to float so that the code will work as expected without any exceptions.
Please let us know if you still face any issues.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Intel(R) UHD Graphics 730 also does not have native support for double precision.
You can change the double data type to float so that the code will work as expected without any exceptions or you can export the below variables so that the code will work without any errors with the double data type.
export OverrideDefaultFP64Settings=1
export IGC_EnableDPEmulation=1
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Since we didn't hear back from you, we assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Noorjahan.
