835 Discussions
OpenMP clause ordering (GPU offload) and is_device_ptr strange behavior
Christos_Kotsalos
I have this very simple example:
#include <stdio.h>
int main() {
  double *ptr = reinterpret_cast<double*>(0xdeadbeef);
  printf("ptr=%p\n", ptr);
  #pragma omp target parallel for simd is_device_ptr(ptr) if(true)
  for(int i = 0; i < 1; ++i) {
  #pragma omp target parallel for simd if(true) is_device_ptr(ptr)
  return 100;
For which I follow these steps in Intel DevCloud:
  1. qsub -I -l nodes=1:gpu:ppn=2 -d .
  2. icpx -qopenmp -fopenmp-targets=spir64 openmp_target_offload_clause_ordering.cpp
  3. export OMP_TARGET_OFFLOAD=MANDATORY
  4. ./a.out
and while it compiles it fails in runtime.
I have tested it with NVIDIA compilers (v22.2) and I had no issue (before the v22.2 there was an issue with the clause ordering -between if and is_device_ptr- but it was a confirmed bug).
I would really apreciate any feedback.
Thank you very much
Best,
Christos
ShivaniK_Intel
From the code snippet you have shared with us we have observed that the pointer you are passing is not a valid device pointer.
Could you please try with the below-changed code snippet and let us know if you further face any issues?
#include <stdio.h>
#include <omp.h>
int main() {
 double *ptr = reinterpret_cast<double*>(omp_target_alloc(size, 0));
 return 100;
Replace:
instead of:
Thanks & Regards
Shivani
ShivaniK_Intel
Thank you for posting in the Intel forums
We are able to reproduce the issue at our end by following the steps you have provided. We are working on it and will get back to you.
Thanks & Regards
Shivani
Christos_Kotsalos
Hi Shivani,
Thank you very much for your quick response.
I am looking forward to hearing from you regarding this compiler issue.
Best,
Christos
ShivaniK_Intel
#include <stdio.h>
#include <omp.h>
int main() {
 return 100;
Replace:
instead of:
Thanks & Regards
Shivani
Christos_Kotsalos
Hi Shivani,
Thank you very much for your prompt response.
Indeed, after your suggestion the code works without any issue.
Thanks for resolving it!
Best,
Christos
ShivaniK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
