887 Discussions
Parallel for is very slow compared to iterative solution
sidrakiyani
I am trying to accelerate an algorithm using DPC++. What happens is that the normal calculation takes 1.5 times faster than kernel parallel execution. The following code is for both calculations.
the num_items currently equals 16,000. I tried small values like 500 but the same thing, the CPU is way faster the kernel.
I am using visual studio 2022 that runs oneAPI dpc++ compiler, and trying to make emulation on an FPGA, but I don't know how to find the details of the FPGA emulator like what frequency it is running on. The full code is: https://ideone.com/iEHQHab
    // This is the normal iterative code.
    std::vector<double> distance_calculation(std::vector<std::vector<double>>& dataset,
    std::vector<double>& curr_test) {
    auto start = std::chrono::high_resolution_clock::now();
    std::vector<double>res;
    for (int i = 0; i < dataset.size(); ++i) {
        double dis = 0;
        for (int j = 0; j < dataset[i].size(); ++j) {
            dis += (curr_test[j] - dataset[i][j]) * (curr_test[j] - dataset[i][j]);
        res.push_back(dis);
    auto finish = std::chrono::high_resolution_clock::now();
    std::chrono::duration<double> elapsed = finish - start;
    std::cout << "Elapsed time: " << elapsed.count() << " s\n";
    return res;
    // This is FPGA emulation code
    std::vector<double> distance_calculation_FPGA(queue& q, const
    std::vector<std::vector<double>>& dataset, const std::vector<double>& curr_test) {
    std::vector<double>linear_dataset;
            linear_dataset.push_back(dataset[i][j]);
    range<1> num_items{dataset.size()};
    //std::cout << "im in" << std::endl;
    res.resize(dataset.size());
    buffer dataset_buf(linear_dataset);
    buffer curr_test_buf(curr_test);
    buffer res_buf(res.data(), num_items);
        q.submit([&](handler& h) {
            accessor a(dataset_buf, h, read_only);
            accessor b(curr_test_buf, h, read_only);
            accessor dif(res_buf, h, read_write, no_init);
            h.parallel_for(range<1>(num_items), [=](id<1> i) {
                //  dif[i] = a[i].size() * 1.0;// a[i];
                for (int j = 0; j < 5; ++j) {
                    dif[i] += (b[j] - a[i * 5 + j]) * (b[j] - a[i * 5 + j]);
            q.wait();
            double dis = 0;
            res.push_back(dis);
    return res;
Steve_Lionel
Barbara_P_Intel
Definitely on the wrong forum. Moving to DPC++ Forum.
