879 Discussions
error compiling Qt 6.3.0 on Windows with oneAPI icx using c++20
Rich_F_1
Attempting to compile Qt 6.3.0 on Windows with oneAPI icx using c++20
was instructed to report the error as a bug by Thiago Macieira.
see bug https://bugreports.qt.io/browse/QTBUG-103605
Do you need me to report the details again here or is the QT bug report enough?
Thanks in advance
Rich
Rich_F_1
The latest patch set 4 provided by Qt has the c++ code-fu needed to make the compiler happy.
As for the problem of getting the configure to work on your end I'm not sure what is going on.
There was a problem extracting the Qt 6.3.0 source code because the file path was too long.
Extracting it to c:\tmp\ then moving it got around that problem.
Otherwise I followed the instructions from here https://doc.qt.io/qt-6/windows-building.html
using the Strawberry Perl.
Changed win32-icc qmake.conf QMAKE_CC = icx
Ran xemacs from the Intel 64 command prompt then configuring and compiling from a shell in xemacs
to capture everything.
NoorjahanSk_Intel
Could you please provide the steps to reproduce the issue at our end?
We have followed the steps that you have posted in the qt forum(https://bugreports.qt.io/browse/QTBUG-103605) but got some issues.
Please find the screenshot of the error log.
Could you please help us in reproducing your issue?
Thanks & Regards,
Noorjahan.
Rich_F_1
NoorjahanSk_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Noorjahan.
