886 Discussions
Problems to compile std::views with oneapi compiler (version 2023.0.0) on linux
MXG
We problems to compile std::views with oneapi compiler (version 2023.0.0) on Linux:
/opt/intel/oneapi/compiler/2023.0.0/linux/bin/icpx -std=c++20 test_view.cxx -o test_view
- it seems to work fine using the same version on Windows.
Attached is the code snippet and the build error log from Redhat 8
Morten Gaupaas
Code snippet:
#include <iostream>
#include <ranges>
using namespace std;
int main()
{ auto even = [](int i) { return 0 == i % 2; };
  auto square = [](int i) { return i * i; };
  for (int i : std::views::iota(0, 6)
             | views::filter(even)
             | std::views::transform(square))
             std::cout << i << ' ';
RabiyaSK_Intel
Could you please try with latest oneAPI toolkit(2023.1 version)?
We didn't face any issues while executing your code on 2023.1 oneAPI toolkit. Please refer to the below screenshot.
If you still face any issues, you can reach out to us.
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
Thanks & Regards,
Shaik Rabiya
MXG
Installed version 2023.1.0 on Linux and it worked fine - thanks!
Morten
RabiyaSK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Shaik Rabiya
