801 Discussions
Unable to use cmake + intel compiler + intel/oneapi-basekit:devel-ubuntu22.04
bungeetux
I was unable to use the intel compiler + cmake with the docker image intel/oneapi-basekit:devel-ubuntu22.04
It complains :
-- Detecting CXX compile features - done
SYCL feature test compile failed!
compile output is:
CMake Error at /opt/intel/oneapi/compiler/2023.0.0/linux/IntelDPCPP/IntelDPCPPConfig.cmake:270 (SYCL_FEATURE_TEST_EXTRACT):
  SYCL_FEATURE_TEST_EXTRACT Function invoked with incorrect arguments for
  function named: SYCL_FEATURE_TEST_EXTRACT
Call Stack (most recent call first):
  CMakeLists.txt:3 (find_package)
I reproduce the problem with this CMakeLists.txt
cmake_minimum_required(VERSION 3.25.1)
project(myproject)
find_package(IntelDPCPP REQUIRED)
Here is a standalone script to reproduce the problem (it is also attached to the message )
#!/bin/bash -x
image=intel/oneapi-basekit:devel-ubuntu22.04
docker pull "$image"
mkdir -p myproject
# cmake_minimum_required(VERSION 3.25.1)
# project(myproject)
# find_package(IntelDPCPP REQUIRED)
echo "cmake_minimum_required(VERSION 3.25.1)" > myproject/CMakeLists.txt
echo "project(myproject)" >> myproject/CMakeLists.txt
echo "find_package(IntelDPCPP REQUIRED)" >> myproject/CMakeLists.txt
# run the test
docker run -v $(pwd):/test -it "$image" /bin/bash -c "cd /test && mkdir -p build && cd build && cmake -DCMAKE_C_COMPILER=icx -DCMAKE_CXX_COMPILER=icx ../myproject"
  Here is the result of the script :
ubuntu@ip-10-0-187-190:~/work2023/dockerbugreport$ ./mytest.sh
+ image=intel/oneapi-basekit:devel-ubuntu22.04
+ docker pull intel/oneapi-basekit:devel-ubuntu22.04
devel-ubuntu22.04: Pulling from intel/oneapi-basekit
Digest: sha256:99220a923d7509285bd60e46e6261d39ff730d6ac23164106eaa9f1e6511d159
Status: Image is up to date for intel/oneapi-basekit:devel-ubuntu22.04
docker.io/intel/oneapi-basekit:devel-ubuntu22.04
+ mkdir -p myproject
+ echo 'cmake_minimum_required(VERSION 3.25.1)'
+ echo 'project(myproject)'
+ echo 'find_package(IntelDPCPP REQUIRED)'
++ pwd
+ docker run -v /home/ubuntu/work2023/dockerbugreport:/test -it intel/oneapi-basekit:devel-ubuntu22.04 /bin/bash -c 'cd /test && mkdir -p build && cd build && cmake -DCMAKE_C_COMPILER=icx -DCMAKE_CXX_COMPILER=icx ../myproject'
-- The C compiler identification is IntelLLVM 2023.0.0
-- The CXX compiler identification is IntelLLVM 2023.0.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /opt/intel/oneapi/compiler/2023.0.0/linux/bin/icx - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /opt/intel/oneapi/compiler/2023.0.0/linux/bin/icx - skipped
compile output is:
-- The SYCL compiler is /opt/intel/oneapi/compiler/2023.0.0/linux/bin/icx
-- The SYCL Flags are -fsycl
-- The SYCL Language Version is
-- Found IntelDPCPP: /opt/intel/oneapi/compiler/2023.0.0/linux/include
-- Configuring incomplete, errors occurred!
See also "/test/build/CMakeFiles/CMakeOutput.log".
NoorjahanSk_Intel
Could you please try with below command while building the CMakeLists.txt file?
cmake -DCMAKE_C_COMPILER=icx -DCMAKE_CXX_COMPILER=icpx ../myproject
We have tried modifying it as mentioned above and did not observe any issues
Please try with above changes and let us know if you face any issues.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan.
bungeetux
Thanks for the solution ,
I was using icx instead of icpx for c++ compiler.
NoorjahanSk_Intel
Thanks for accepting our solution.
As this issue has been resolved, we will no longer respond to this thread. If you need any additional information, please post a new question
Thanks & Regards,
Noorjahan.
