SYCL USM on integrated devices
amimar2
SYCL USM will work on discrete GPU if-and-only-if the GPU's hardware supports unified virtual address space.
What is case regarding integrated GPUs?
Can we assume that any integrated GPU supports USM?
VaishnaviV_Intel
Thanks for posting on Intel communities.
Yes, integrated GPUs support Unified shared memory. Unified Shared Memory (USM) is a feature that allows both the CPU and GPU to access the same memory space directly, simplifying data sharing between the two processing units.
For more information on Unified shared memory please refer to the following links,
https://www.intel.com/content/www/us/en/docs/oneapi/optimization-guide-gpu/2023-1/unified-shared-memory-allocations.html
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-dpcpp-system-requirements.html
https://www.intel.com/content/www/us/en/docs/oneapi/optimization-guide-gpu/2023-0/host-device-memory-buffer-and-usm.html
A book on Data Parallel C++: Mastering DPC++ for Programming of Heterogeneous Systems using C++ and SYCL- James Reinders
Thanks & Regards,
Vankudothu Vaishnavi.
VaishnaviV_Intel
Thanks & Regards,
VaishnaviV_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
