891 Discussions
Unable to run program using MS visual studio when using library built with DPC++ compiler
student4
I have C++ library built using DPC++ compiler. I used this library in a test project file. I then built the test project file using Microsoft visual studio compiler(Please note that the test project contains only C++ libraries). But when I tried to run the program, it throws the error sycl.dll not found.
I appreciate your assistance on this regard.
It works perfectly when the test project is built using DPC++ compiler.
Thank you.
DitiD_Intel
>> Using Microsoft visual studio compiler ... But when I tried to run the program, it throws the error sycl.dll not found.
As this issue is related to non intel compilers, we would not be able to provide support for that.
Additionally, if your cpp library doesn't contain any sycl functions then instead of using dpcpp compiler to build the library, I'd suggest you to try it out with icx or icl.
The Intel® oneAPI DPC++/C++ Compiler compiles C++-based SYCL* source files for a wide range of compute accelerators. That is the reason you are not getting error when trying with dpcpp compiler.
https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-dpcpp-compiler/top.html
Thanks & Regards,
Ditipriya.
DitiD_Intel
We've not heard back from you. Can you please provide an update?
Thanks and Regards,
Ditipriya.
DitiD_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Ditipriya.
