cl::sycl::runtime_error
ssln027
I optimized a program by using dpc++. The solution can be successfully built and generated, but a runtime error was met. The error message is shown below.
Details info:
HW: TGL
OS: win10
SW: oneAPI 2021.4 and 2022 base toolkit
        Visual Studio 2019
DitiD_Intel
Could you please provide us with a sample reproducer so that we can investigate your issue from our end.
Also, could you please confirm whether you are facing the issue with both 2021.4 and 2022 versions?
Thanks and Regards,
Ditipriya.
Alex_Y_Intel
I would need a small reproducer that can demonstrate the problem you've observed to investigate. Thanks.
Alex_Y_Intel
I tried the machine you provided, and the source code downloaded from https://github.com/intel-innersource/frameworks.industrial.robotics.vision.flann, and opened it in MSVS 2019 by doing File->Open->CMake, and I chose the CmakeLists.tst in the root directory. However, right after it’s opened in the MSVS, it showed me the error:
By the way, this link: https://gitlab.devtools.intel.com/-/invites/yWhJpVpib3jJY-Jy9kjz?invite_type=initial_email showed me 404 error.
Anyways, can you please let me know the exact steps of reproducing what you’ve observed? Thanks.
