888 Discussions
Understanding Performance of Modified Vector Add Example
Austin1
I'd like to understand the excess overhead I'm measuring when submitting a sycl command group in the attached modified vector add example.  Some key points:
  • Vector add works on 100M complex elements and writes to output vector sum
  • Target: CPU with 2 cores
  • Profiling overall command group, and using sycl profiling to track submit time and execution time
I'm finding that the overall execution time is about 7 times longer than the execution + submit time.  I'm curious to know the source of the additional overhead when submitting the command group.
Even when the kernel has no work (comment contents in parallel for) and set array_size = 1, the overall overhead is still half a second (much larger than the kernel submit time or execution time)
Note: I'm using the latest Intel oneAPI DPC++ Compiler included in the Basekit_p_2021.1.0.2659 release.
Thanks for your help.
#include <CL/sycl.hpp>
#include <complex>
constexpr sycl::access::mode dp_read = sycl::access::mode::read;
constexpr sycl::access::mode dp_write = sycl::access::mode::write;
constexpr size_t array_size = 100000000;
typedef std::vector<std::complex<float>> IntArray;
// Function description: initialize the array from 0 to array_size-1
void initialize_array(IntArray &a) {
  for (size_t i = 0; i < a.size(); i++){
 float x = (float) i;
 float y = -x;
 a[i] = std::complex<float>(x, y);
// Compute vector addition in DPC++ on device: sum of the data is returned in
// 3rd parameter "sum_parallel"
void VectorAddInDPCPP(const IntArray &addend_1, const IntArray &addend_2,
                      IntArray &sum_parallel) {
  auto property_list = cl::sycl::property_list{cl::sycl::property::queue::enable_profiling()};
  sycl::queue q = cl::sycl::queue(sycl::cpu_selector{}, property_list);
  // print out the device information used for the kernel code
  std::cout << "Device: " << q.get_device().get_info<sycl::info::device::name>()
            << std::endl;
  std::cout << "Compute Units: " << q.get_device().get_info<sycl::info::device::max_compute_units>()
              << std::endl;
  // create the range object for the arrays managed by the buffer
  sycl::range<1> num_items{array_size};
  sycl::buffer<std::complex<float>, 1> addend_1_buf(addend_1.data(), num_items);
  sycl::buffer<std::complex<float>, 1> addend_2_buf(addend_2.data(), num_items);
  sycl::buffer<std::complex<float>, 1> sum_buf(sum_parallel.data(), num_items);
  auto start_overall = std::chrono::system_clock::now();
  // submit a command group to the queue by a lambda function that
  // contains the data access permission and device computation (kernel)
  auto event = q.submit([&](sycl::handler &h) {
    auto addend_1_accessor = addend_1_buf.get_access<dp_read>(h);
    auto addend_2_accessor = addend_2_buf.get_access<dp_read>(h);
    auto sum_accessor = sum_buf.get_access<dp_write>(h);
    h.parallel_for(num_items, [=](sycl::id<1> i) {
    float real = addend_1_accessor[i].real() + addend_2_accessor[i].real();
    float imag = addend_1_accessor[i].imag() + addend_2_accessor[i].imag();
    sum_accessor[i] = std::complex<float>(real, imag);
  event.wait();
  auto end_overall = std::chrono::system_clock::now();
  auto submit_time = event.get_profiling_info<cl::sycl::info::event_profiling::command_submit>();
  auto start_time = event.get_profiling_info<cl::sycl::info::event_profiling::command_start>();
  auto end_time = event.get_profiling_info<cl::sycl::info::event_profiling::command_end>();
  auto submission_time = (start_time - submit_time) / 1000000.0f;
  std::cout << "Submit Time: " << submission_time << " ms" <<  std::endl;
  auto execution_time = (end_time - start_time) / 1000000.0f;
  std::cout << "Execution Time: " << execution_time << " ms" << std::endl;
  auto execution_overall = std::chrono::duration_cast<std::chrono::milliseconds>(end_overall - start_overall);
  std::cout << "Overall Execution Time: " << execution_overall.count() << " ms" << std::endl;
// Demonstrate summation of arrays both in scalar on CPU and parallel on device
int main() {
  // Vector Add using SYCL
  IntArray addend_1 (array_size);
  IntArray addend_2 (array_size);
  IntArray sum_parallel (array_size);
  initialize_array(addend_1);
  initialize_array(addend_2);
  VectorAddInDPCPP(addend_1, addend_2, sum_parallel);
  // Vector Add on host single threaded
  IntArray sum_scalar (array_size);
  for (size_t i = 0; i < sum_scalar.size(); i++){
 float real = addend_1[i].real() + addend_2[i].real();
 float imag = addend_1[i].imag() + addend_2[i].imag();
 sum_scalar[i] = std::complex<float>(real, imag);
  // Verify both sum arrays are equal
  for (size_t i = 0; i < sum_parallel.size(); i++) {
    if ((sum_parallel[i] != sum_scalar[i])) {
    std::cout << "i = " << i << " , sum_parallel[i].real() = " << sum_parallel[i].real() << std::endl;
    std::cout << "i = " << i << " , sum_scalar[i].real() = " << sum_scalar[i].real() << std::endl;
    std::cout << "fail" << std::endl;
      return -1;
  std::cout << "success" << std::endl;
  return 0;
GouthamK_Intel
Hi Austin,
We are escalating this thread to the Subject Matter Expert(SME) who will guide you further.
Have a Good day!
Thanks & Regards
Goutham
JenniferJ
This is an interesting finding.
There're a couple important overhead for each kernel:
  • JIT compilation for each kernel: it happens once for each kernel
  • Data transfer between CPU memory & GPU memory
Those are not counted by the submit-time and execution-time. But the overall system clock you have included all, so it's slower.
There is an open-source tool https://github.com/intel/pti-gpu/tree/master/samples/ze_tracer that can show more details on where the time spent. It may help.
Hope answers your questions.
Jennifer
