Using printf inside kernel code
student4
This screenshot is taken from Intel oneAPI Programming Guide(pg 44).
According to the documentation, printf can be used inside the kernel code for debugging.
But when I used inside my kernel code, it shows an error 'sycl kernel cannot call undefined function'.
q.submit([&](sycl::handler& h){
h.single_task([=]() {
printf
Appreciate your help.
Thank you.
QM
That's because you are not calling the function with right syntax. printf(...) is in cl::sycl::ext::oneapi::experimental namespace, you need to specify a namespace for an external function. I would recommend using sycl::stream for the ease of use.
HemanthCH_Intel
We haven't heard back from you. Could you please provide any updates on your issue?
Thanks & Regards,
Hemanth
HemanthCH_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
