oneapi 2023.2.0 compiler failure
Jam1
 Hi
    I am in the process of testing oneapi release 2023.2.0 and I am getting the following compiler front end crash
#39 0x000055db1e592b4e main (/opt/intel/oneapi/compiler/2023.2.0/linux/bin-llvm/clang+++0x3cf4b4e)
#40 0x00007f12506b5555 __libc_start_main (/usr/lib64/libc.so.6+0x22555)
#41 0x000055db1e582e29 _start (/opt/intel/oneapi/compiler/2023.2.0/linux/bin-llvm/clang+++0x3ce4e29)
icpx: error: clang frontend command failed with exit code 139 (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2023.2.0 (2023.2.0.20230622)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2023.2.0/linux/bin-llvm
Configuration file: /opt/intel/oneapi/compiler/2023.2.0/linux/bin-llvm/../bin/icpx.cfg
icpx: note: diagnostic msg:
PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
Preprocessed source(s) and associated run script(s) are located at:
icpx: note: diagnostic msg: /tmp/icpx-573df6/Upwind-ca867d.cpp
icpx: note: diagnostic msg: /tmp/icpx-573df6/Upwind-ca867d.sh
Config:
 Centos 7
 devtoolset-11
 oneapi base + hpc 2023.2.0
I would prefer to send the diagnostic files directly if possible
 Jamil
RabiyaSK_Intel
Can you please try on supported Operating System as CentOS is not supported by Intel Base Toolkit and Intel DPC++/C++ compiler. Please refer to the following links for system requirements:
Intel oneAPI Base Toolkit:
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-base-toolkit-system-requirements.html
Intel oneAPI DPC++/C++ Compiler:
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-dpcpp-system-requirements.html
If you are still facing issues, please provide sample reproducer and steps to reproduce.
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
We haven't heard back from you. Can you please respond to my previous post?
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
We haven't heard back from you. If you need any additional information, you can raise a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Shaik Rabiya
