support for Intel® Iris® Plus Graphics 640
Saidani__Tarik
Is DPC++ supported on Intel® Iris® Plus Graphics 640?
When I run the following code:
#include <iostream>
#include <CL/sycl.hpp>
int main()
    cl::sycl::queue q(cl::sycl::gpu_selector{});
    auto device = q.get_device();
    std::cout << "device name is: " << device.get_info<cl::sycl::info::device::name>() << std::endl;
I get
terminate called after throwing an instance of 'cl::sycl::runtime_error'
  what():  No device of requested type available. 0 (CL_SUCCESS)
Aborted
RahulV_intel
Thanks for reaching out to us. We will get back to you soon.
Rahul
JyotsnaK_Intel
Hi Tarik,
Please could you send output of "lspci" command for more details.
Saidani__Tarik
Hi Jyotsna,
Just to be more specific I'm trying to run the program from within a intel/oneapi-hpckit Docker container. The reason being that I'm running it from my MacBook Pro (13-inch, 2017). There is no MacOS package for intel oneAPI at the moment, so that's the workaround I found. From the lspci output (see below) I can tell that the GPU is not detected in the container. Do you have any idea of a Docker run option that makes the GPU driver available ?
Many Thanks,
Tarik
lspci
00:00.0 Host bridge: Network Appliance Corporation Device 1275
00:01.0 Ethernet controller: Red Hat, Inc. Virtio network device
00:02.0 SATA controller: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 6 port SATA Controller [AHCI mode]
00:03.0 Ethernet controller: Red Hat, Inc. Device 103f
00:04.0 SATA controller: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 6 port SATA Controller [AHCI mode]
00:05.0 SATA controller: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 6 port SATA Controller [AHCI mode]
00:06.0 SATA controller: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 6 port SATA Controller [AHCI mode]
00:07.0 Network and computing encryption device: Red Hat, Inc. Virtio RNG
00:1f.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
Sravani_K_Intel
Hi Tarik,
The docker run option  "--device=/dev/dri" enables the GPU(if available) as mentioned in the Get Started with the Intel® oneAPI Toolkits for Linux* .
Let us know if you still see the issue.
