Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel® DPC++ Compatibility Tool, and GDB*
Problem using ndrange with Intel Graphics
QM
I am using DPC++ to enable parallelization for my code. Using sycl::ndrange<1>{N, worker_number} works totally fine when run on CPU (using sycl::host_selector{}). However, when I switch to Intel graphics by using sycl::default_selector{}, the errors are caused by the use of ndrange ( switch to range approach works).
I am using Intel (R) UHD Graphics.
Does anybody know what's wrong with it?
Here is details of my dpcpp version:
-Intel(R) oneAPI DPC++/C++ Compiler 2022.0.0 (2022.0.0.20211123)
-Target: x86_64-pc-windows-msvc
-Thread model: posix
Q
DitiD_Intel
Since this is a duplicate thread of <https://community.intel.com/t5/GPU-Compute-Software/Problem-using-ndrange-with-Intel-Graphics/m-p/1379899#M422>, we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Thanks and Regards,
Ditipriya.
