Intel® MPI Library
Disconnect VPN causes parallel computing with Intel MPI to stop
hsu__jim
Principiante
7.754 Visualizações
Hi:
Our software product is based on Intel MPI for parallel computing on Windows.
Recently many of our customers encounter this error. Due to COVID-19, they all work at home with VPN connection to the office.
They run our software for parallel computing at home, but when they disconnect VPN, the parallel computing is stopped at the same time.
I can reproduce the error by the following steps:
1. Run IMB-MPI1.exe with the command:   mpiexec.exe -localonly -n 4 C:\test\IMB-MPI1.exe
2. While IMB-MPI1.exe is still running, I disable any of the network interfaces (I have 3 NICs, 2 are created by VMware, 1 is physical NIC.) and got the following errors
       #bytes #repetitions  t_min[usec]  t_max[usec]  t_avg[usec]
            0         1000         0.05         0.06         0.06
            1         1000         0.77         0.79         0.78
            2         1000         0.86         0.87         0.86
            4         1000         0.86         0.90         0.88
            8         1000         0.78         0.80         0.79
           16         1000         1.01         1.15         1.08
           32         1000         1.18         1.22         1.20
           64         1000         0.87         0.90         0.88
          128         1000         1.31         1.36         1.34
          256         1000         1.29         1.35         1.31
          512         1000         1.52         1.57         1.55
         1024         1000         1.45         1.47         1.46
         2048         1000         2.57         2.77         2.67
         4096         1000         3.60         4.05         3.88
         8192         1000         4.99         5.31         5.13
        16384         1000         8.44         8.74         8.52
        32768         1000        14.06        14.34        14.14
        65536          640        35.06        35.86        35.47
       131072          320        59.00        67.31        63.18
       262144          160       156.66       167.80       161.57
       524288           80       869.78       896.27       880.66
      1048576           40      2402.85      2564.92      2484.02
      2097152           20      4692.22      4907.47      4789.06
[mpiexec@PCAcer144006] ..\hydra\pm\pmiserv\pmiserv_cb.c (863): connection to proxy 0 at host PCAcer144006 failed
[mpiexec@PCAcer144006] ..\hydra\tools\demux\demux_select.c (103): callback returned error status
[mpiexec@PCAcer144006] ..\hydra\pm\pmiserv\pmiserv_pmci.c (520): error waiting for event
[mpiexec@PCAcer144006] ..\hydra\ui\mpich\mpiexec.c (1157): process manager error waiting for completion
C:\Program Files\Intel MPI 2018\x64>
Is there any workaround ?  Thank you
1 Solução
PrasanthD_intel
Moderador
7.754 Visualizações
Hi Jim,
Previously we have tested with the latest IMPI version instead of IMPI 2018u5, which is why we haven't got that error.
We have tested with 2018u5 and got that error. So there seems to be a bug which has been fixed in later versions
We suggest you upgrade to the latest version of IMPI (currently 2019u7).
Prasanth
Ver solução na publicação original
10 Respostas
PrasanthD_intel
Moderador
7.754 Visualizações
Hi Jim,
The error you are seeing is caused because one of the processes in your job ended incorrectly or one of your processes has had a segmentation fault[ This means reading from or writing to an area of memory that it is not permitted to].
Could you provide the logs after setting FI_LOG_LEVEL=debug  I_MPI_DEBUG=5
Are you sure even after disconnecting the VPN the system can communicate with the node in which processes have been launched?
Prasanth
PrasanthD_intel
Moderador
7.754 Visualizações
Hi Jim,
Are you still facing the issue?
If yes, please provide the details we have asked it will help us debug the issue.
Prasanth
hsu__jim
Principiante
7.754 Visualizações
Hi Prasanth:
VPN issue occurred in my client's environment. But I think it's similar to what I test in my environment.
In my own environment, I have only 1 PC, which has 1 physical network interface and 2 virtual network interface created by VMware.
I run IMB-MPI.exe and before it finishes I disable one virtual network interface, then I got the MPI error.
My question is why running with "-localonly" is related to "disabling network interface".
C:\>"C:\Program Files\Intel MPI 2018\x64\mpiexec.exe" -localonly -n 4 -genv I_MPI_DEBUG 5 -genv FI_LOG_LEVEL debug C:\test\IMB-MPI1.exe
[0] MPI startup(): Multi-threaded optimized library
[0] MPI startup(): shm data transfer mode
[1] MPI startup(): shm data transfer mode
[2] MPI startup(): shm data transfer mode
[3] MPI startup(): shm data transfer mode
[1] MPI startup(): Internal info: pinning initialization was done
[0] MPI startup(): Internal info: pinning initialization was done
[2] MPI startup(): Internal info: pinning initialization was done
[3] MPI startup(): Internal info: pinning initialization was done
[0] MPI startup(): Rank    Pid      Node name     Pin cpu
[0] MPI startup(): 0       1124     PCAcer144006  {0,1}
[0] MPI startup(): 1       8256     PCAcer144006  {2,3}
[0] MPI startup(): 2       10636    PCAcer144006  {4,5}
[0] MPI startup(): 3       7604     PCAcer144006  {6,7}
[0] MPI startup(): I_MPI_DEBUG=5
[0] MPI startup(): I_MPI_PIN_MAPPING=4:0 0,1 2,2 4,3 6
#    Intel (R) MPI Benchmarks 2018, MPI-1 part
# Date                  : Wed May 06 09:38:14 2020
# Machine               : Intel(R) 64 Family 6 Model 60 Stepping 3, GenuineIntel
# Release               : 6.2.9200
# Version               :
# MPI Version           : 3.1
# MPI Thread Environment:
# Calling sequence was:
# C:\test\IMB-MPI1.exe
# Minimum message length in bytes:   0
# Maximum message length in bytes:   4194304
# MPI_Datatype                   :   MPI_BYTE
# MPI_Datatype for reductions    :   MPI_FLOAT
# MPI_Op                         :   MPI_SUM
# List of Benchmarks to run:
# PingPong
# PingPing
# Sendrecv
# Exchange
# Allreduce
# Reduce
# Reduce_scatter
# Allgather
# Allgatherv
# Gather
# Gatherv
# Scatter
# Scatterv
# Alltoall
# Alltoallv
# Bcast
# Barrier
# Benchmarking PingPong
# #processes = 2
# ( 2 additional processes waiting in MPI_Barrier)
       #bytes #repetitions      t[usec]   Mbytes/sec
            0         1000         0.17         0.00
            1         1000         0.19         5.38
            2         1000         0.23         8.74
            4         1000         0.17        22.88
            8         1000         0.23        34.39
           16         1000         0.22        72.46
           32         1000         0.23       139.98
           64         1000         0.25       253.62
          128         1000         0.26       483.66
          256         1000         0.28       930.91
          512         1000         0.31      1627.72
         1024         1000         0.34      2978.48
         2048         1000         0.46      4430.98
         4096         1000         0.68      6066.35
         8192         1000         1.23      6647.46
        16384         1000         2.32      7072.43
        32768         1000         3.73      8775.11
        65536          640         8.29      7902.37
       131072          320        15.10      8682.69
       262144          160        29.76      8810.08
       524288           80        53.14      9865.82
      1048576           40       104.31     10052.62
      2097152           20       249.32      8411.40
      4194304           10       814.33      5150.65
# Benchmarking PingPing
# #processes = 2
            0         1000         0.26         0.00
            1         1000         0.51         1.96
            2         1000         0.26         7.68
            4         1000         0.26        15.23
            8         1000         0.26        30.77
           16         1000         0.35        45.18
           32         1000         0.30       107.02
           64         1000         0.28       225.19
          128         1000         0.38       340.52
          256         1000         0.39       659.62
          512         1000         0.42      1221.67
         1024         1000         0.44      2319.89
         2048         1000         0.69      2974.15
         4096         1000         0.90      4527.97
         8192         1000         1.33      6174.72
        16384         1000         2.62      6245.33
        32768         1000         4.79      6843.49
        65536          640        11.94      5487.05
       131072          320        19.68      6660.06
       262144          160        36.10      7261.10
       524288           80        67.10      7813.10
      1048576           40       131.38      7981.40
      2097152           20       439.42      4772.55
      4194304           10      1596.74      2626.79
# Benchmarking Sendrecv
# #processes = 2
       #bytes #repetitions  t_min[usec]  t_max[usec]  t_avg[usec]   Mbytes/sec
            0         1000         0.40         0.40         0.40         0.00
            1         1000         0.39         0.39         0.39         5.18
            2         1000         0.67         0.67         0.67         6.01
            4         1000         0.38         0.38         0.38        21.29
            8         1000         0.40         0.40         0.40        40.26
           16         1000         0.45         0.45         0.45        71.06
           32         1000         0.46         0.46         0.46       138.20
           64         1000         0.46         0.46         0.46       279.05
          128         1000         1.05         1.05         1.05       244.00
          256         1000         3.01         3.06         3.04       167.15
          512         1000         0.58         0.58         0.58      1780.87
         1024         1000         0.93         0.93         0.93      2204.76
         2048         1000         0.99         0.99         0.99      4133.62
         4096         1000         1.02         1.02         1.02      8014.09
         8192         1000         1.62         1.62         1.62     10091.78
        16384         1000         3.03         3.03         3.03     10807.74
        32768         1000         4.29         4.29         4.29     15290.71
        65536          640        11.81        11.81        11.81     11094.87
       131072          320        37.92        37.92        37.92      6913.37
       262144          160        74.20        74.20        74.20      7065.64
       524288           80        72.93        72.93        72.93     14377.10
      1048576           40       127.65       127.66       127.65     16427.96
      2097152           20       399.46       399.52       399.49     10498.49
      4194304           10      1420.54      1420.81      1420.68      5904.10
# #processes = 4
            0         1000         0.50         0.50         0.50         0.00
            1         1000         0.45         0.45         0.45         4.45
            2         1000         0.47         0.47         0.47         8.52
            4         1000         0.45         0.45         0.45        17.91
            8         1000         0.59         0.59         0.59        27.16
           16         1000         0.46         0.46         0.46        69.04
           32         1000         0.46         0.46         0.46       139.01
           64         1000         0.48         0.48         0.48       267.06
          128         1000         0.60         0.60         0.60       425.60
          256         1000         0.59         0.59         0.59       861.08
          512         1000         0.66         0.66         0.66      1540.31
         1024         1000         0.71         0.71         0.71      2881.67
         2048         1000         0.86         0.86         0.86      4766.67
         4096         1000         1.16         1.17         1.17      7011.30
         8192         1000         1.76         1.76         1.76      9288.51
        16384         1000         2.89         2.89         2.89     11345.08
        32768         1000         4.66         4.66         4.66     14051.76
        65536          640        18.42        18.44        18.43      7109.17
       131072          320        33.06        33.12        33.09      7915.72
       262144          160        60.25        60.41        60.33      8678.74
       524288           80       108.77       109.02       108.90      9618.09
      1048576           40       336.31       340.51       338.59      6158.81
      2097152           20      1149.49      1168.46      1159.12      3589.62
      4194304           10      2544.51      2626.74      2585.81      3193.54
# Benchmarking Exchange
# #processes = 2
            0         1000         0.87         0.87         0.87         0.00
            1         1000         0.60         0.60         0.60         6.72
            2         1000         0.68         0.68         0.68        11.68
            4         1000         0.60         0.60         0.60        26.74
            8         1000         0.57         0.57         0.57        55.99
           16         1000         0.69         0.69         0.69        93.00
           32         1000         0.65         0.65         0.65       198.30
           64         1000         0.69         0.69         0.69       371.66
          128         1000         0.88         0.88         0.88       584.01
          256         1000         0.87         0.87         0.87      1172.30
          512         1000         0.94         0.94         0.94      2175.02
         1024         1000         1.00         1.00         1.00      4086.19
         2048         1000         1.29         1.29         1.29      6335.65
         4096         1000         1.74         1.74         1.74      9401.50
         8192         1000         2.80         2.80         2.80     11708.71
        16384         1000         5.07         5.07         5.07     12936.18
        32768         1000         8.74         8.74         8.74     14990.79
        65536          640        24.43        24.43        24.43     10729.59
       131072          320        33.24        33.24        33.24     15774.44
       262144          160        72.37        72.38        72.37     14487.97
       524288           80       136.95       136.97       136.96     15311.17
      1048576           40       294.08       294.14       294.11     14259.43
      2097152           20       772.77       772.93       772.85     10852.93
      4194304           10      2644.70      2645.16      2644.93      6342.61
# #processes = 4
            0         1000         1.03         1.03         1.03         0.00
            1         1000         1.00         1.01         1.01         3.98
            2         1000         1.13         1.13         1.13         7.07
            4         1000         1.04         1.04         1.04        15.32
            8         1000         0.97         0.97         0.97        33.10
           16         1000         1.00         1.00         1.00        64.13
           32         1000         1.12         1.12         1.12       113.85
           64         1000         1.10         1.10         1.10       232.35
          128         1000         1.29         1.29         1.29       396.81
          256         1000         1.24         1.25         1.24       822.16
          512         1000         1.33         1.34         1.33      1533.97
         1024         1000         1.48         1.48         1.48      2758.99
         2048         1000         1.81         1.81         1.81      4530.22
         4096         1000         2.92         2.92         2.92      5615.00
         8192         1000         3.98         3.98         3.98      8228.41
        16384         1000         6.92         6.93         6.93      9461.09
        32768         1000        13.41        13.42        13.41      9769.97
        65536          640        25.53        25.55        25.54     10259.79
       131072          320        43.11        43.13        43.12     12156.87
       262144          160        75.47        75.59        75.53     13871.89
       524288           80       198.98       199.03       199.01     10536.93
      1048576           40       635.41       636.96       636.41      6584.85
      2097152           20      1987.81      1993.80      1991.49      4207.35
      4194304           10      4715.18      4717.40      4716.28      3556.45
# Benchmarking Allreduce
# #processes = 2
            0         1000         0.05         0.05         0.05
            4         1000         0.41         0.42         0.42
            8         1000         0.42         0.43         0.42
           16         1000         0.44         0.44         0.44
           32         1000         0.43         0.44         0.44
           64         1000         0.44         0.44         0.44
          128         1000         0.59         0.60         0.59
          256         1000         0.59         0.60         0.60
          512         1000         0.66         0.72         0.69
         1024         1000         0.73         0.80         0.77
         2048         1000         0.87         0.91         0.89
         4096         1000         1.22         1.25         1.23
         8192         1000         2.30         2.37         2.34
        16384         1000         3.96         4.02         3.99
        32768         1000         7.19         7.19         7.19
        65536          640        11.92        11.96        11.94
       131072          320        63.15        63.70        63.43
       262144          160        71.74        72.39        72.06
       524288           80       126.79       127.65       127.22
      1048576           40       459.69       469.03       464.36
C:\>
PrasanthD_intel
Moderador
7.754 Visualizações
Hi Jim,
We want to replicate your scenario at our end.
Could you please provide the following details:
1)VMware version
2) OS version running in VMware
3)Network Adapter details
Prasanth
hsu__jim
Principiante
7.754 Visualizações
Hi Prasanth:
1. VMWare version:
2. OS running in VMware are : CentOS 7.2 x64 and CentOS 8.1 x64 (both are powered off when running IMB-MPI1.exe)
3. Network adpater details:
(a) VMnet1
(b) VMnet8
(c) Physical NIC
regards,
Jim
PrasanthD_intel
Moderador
7.754 Visualizações
Hi Jim,
We have tried to replicate your issue and here are the setup details:
1) VMWare workstation pro 15
2) 2 CentOS 8.1 VMs
3) For Virtual Network Interface we have set the Custom: Specific virtual network to VMnet0
We have tried to reproduce the error by recreating 3 scenarios based on your inputs
1)    Disconnect VPN while the benchmark is running.
2)    Disable/ switch off the Virtual network interface while the benchmark is running.
       (We have disabled the network adapter in Control Panel\Network and Internet\Network Connections, also we switched off the Virtual machine as another case)
3)    Disconnect VPN and Disable/ switch off the Virtual network interface while the benchmark is running.
We haven't got any errors in either of those scenarios.
We are not sure what we are missing here, can you give us any more inputs?
Prasanth
hsu__jim
Principiante
7.754 Visualizações
Hi Prasanth:
I uninstall VMware. Now there is only 1 physical network adapter in my computer.
I reinstall Intel MPI 2018 update 5 (w_mpi_p_2018.5.287.exe)
I cd to C:\Program Files (x86)\IntelSWTools\mpi\2018.5.287\intel64\bin
I run:
mpiexec.exe -localonly -n 4 IMB-MPI1.exe
During IMB-MPI1.exe is running, I disable the physical network adapter, and IMB-MPI1.exe is aborted with same errors.
The video: https://test-bucket-3a7c4c82.s3.amazonaws.com/mpi.mp4
regards,
Jim
PrasanthD_intel
Moderador
7.755 Visualizações
Hi Jim,
Prasanth
PrasanthD_intel
Moderador
7.754 Visualizações
Hi Jim,
Could you please confirm that updating the IMPI resolved your issue.
Else please let us know the problem you were facing.
Prasanth
hsu__jim
Principiante
7.754 Visualizações
Hi Prasanth:
Intel MPI 2019 update 7 indeed resolves the VPN issue.
Thank you.
regards,
Jim
Responder
