8 byte integer version of pardiso
wjiang123
Dear users of pardiso,
I found in MKL reference manual that argument pt(64) must be defined as INTEGER*8 for 64-bit architectures. What about other integer type parameters? Is the present version supporting 8 byte integers? Thanks,
Wen
Gennady_F_Intel
Wen,
If we are talking about Pardiso, then 2 options:
for ILP64 interface all integer types are INTEGER*8,
but for LP64 interface not, all integer types are 4 bytes
as an example, please look at $MKLROOT/examples/solver/source/pardiso_sym_c.c
you can see there:
#if defined(MKL_ILP64)
#define MKL_INT long long
#else
#define MKL_INT int
#endif
More info about LP64 and ILP64 interfaces concepts you can find into MKL User Guide ( see Chapter 3, Support for ILP64 Programming )
PS:
Note that some Intel MKL functions ( not Pardiso ) and subroutines have scalar or array parameters of
type INTEGER*4 or INTEGER(KIND=4), which are always 4-byte, regardless of whether the
code is compiled with the /4I8 option.
--Gennady
Gennady_F_Intel
Wen,
you can see there:
#else
#define MKL_INT int
#endif
PS:
--Gennady
