VC++ 2005: static library containing MKL
jd_weeks
I am trying to build a static library that includes calls to MKL. This library will be used by others to build applications that depend on code that uses MKL.
I made a static library project, added my C++ source files, and included mkl_c.lib, mkl_ia32.lib, mkl_lapack.lib and libguide.lib as inputs to the static library.
Building the static library results in a number of warnings of duplicate symbols. Is this because of multiple architecture implementations in MKL? How do I resolve this?
Building an application using this library complains "cannot open file mkl_ia32.lib". Why would the application be looking for mkl_ia32.lib? How can I fix this?
Thanks in advance!
eddy_alonso
Quoting - jd_weeks
Thanks in advance!
eddy_alonso
Quoting - jd_weeks
Thanks in advance!
Did you get an answer? I have exactly the same problem. I embed mkl functionality in one library mylib.lib by linking statically to mkl_c.lib. When I try to link to mylib.lib from another application, I get LNK1104: cannot open file 'mkl_ia32.lib' I am using the 9.1.025 version. Can anyone help me? Thanks in advance
Gennady_F_Intel
Alonso,
You dont need to explicitly link mkl_ia32.lib.
I would recommend you to look in MKL Users Guide, there you can find a lot of Linking Examples (see Chapter 5) as well our Note on Linking with libguide.
I hope it will help you to resolve the problem.
--Gennady
