7302 Discussions
ATTENTION: Read if you cannot install from deb feed: The APT distribution key has expired today
KKats1
The key listed on the instruction page
https://software.intel.com/en-us/articles/installing-intel-free-libs-and-python-apt-repo
specifically, this file:
wget https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB
is old, and has just expired. There will be a million failures; do not panic; I hope Intel will fix that very quickly.
# curl -Ss https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB | gpg -
gpg: WARNING: no command supplied.  Trying to guess what you mean ...
pub   rsa2048 2016-09-28 [SC] [expired: 2019-09-27]  <<<=== THIS
      BF4385F91CA5FC005AB39E1C1A8497B11911E097
uid           "CN = Intel(R) Software Development Products", O=Intel Corporation
Update: The rpm feeds are reportedly also affected.
Gennady_F_Intel
Thanks for the report. the issue is escalated and we will fix the issue asap.
Gennady_F_Intel
Could you try the package once again right now? The packages should be re-signed.
KKats1
Sure, tested and found no problems. 'apt update' passed (so that the Release file signature is ok). I also installed, just for testing, intel-psxe-common-2018.0-033, intel-psxe-common-2019.2-057, intel-psxe-common-2019.5-075 -- all three packages checked out good, too, no complaints from dpkg.
Thanks for the update!
Kula__Wojciech
For me it's still not working - I'm receiving following error:
WARNING: The following packages cannot be authenticated!
  intel-comp-l-all-vars-19.0.1-144 intel-comp-nomcu-vars-19.0.1-144
  intel-conda-index-tool-19.0.1-144
  intel-conda-intel-openmp-linux-64-shadow-package-2019.1-144
  intel-tbb-libs-2019.2-144 intel-conda-tbb-linux-64-shadow-package-2019.2-144
  intel-openmp-19.0.1-144 intel-mkl-doc-2019 intel-mkl-common-2019.1-144
  intel-mkl-core-rt-2019.1-144 intel-mkl-core-2019.1-144
  intel-conda-mkl-linux-64-shadow-package-2019.1-144
  intel-conda-mkl-include-linux-64-shadow-package-2019.1-144
  intel-conda-mkl-devel-linux-64-shadow-package-2019.1-144
  intel-conda-mkl-static-linux-64-shadow-package-2019.1-144
  intel-mkl-cluster-rt-2019.1-144 intel-mkl-cluster-2019.1-144
  intel-mkl-common-c-2019.1-144 intel-mkl-cluster-c-2019.1-144
  intel-mkl-common-f-2019.1-144 intel-mkl-cluster-f-2019.1-144
  intel-mkl-common-ps-2019.1-144 intel-mkl-doc-ps-2019
  intel-mkl-common-c-ps-2019.1-144 intel-mkl-core-c-2019.1-144
  intel-mkl-core-f-2019.1-144 intel-mkl-core-ps-2019.1-144
  intel-mkl-f95-common-2019.1-144 intel-mkl-f95-2019.1-144
  intel-mkl-gnu-rt-2019.1-144 intel-mkl-gnu-2019.1-144
  intel-mkl-gnu-c-2019.1-144 intel-mkl-gnu-f-rt-2019.1-144
  intel-mkl-gnu-f-2019.1-144 intel-mkl-pgi-rt-2019.1-144
  intel-mkl-pgi-2019.1-144 intel-mkl-pgi-c-2019.1-144
  intel-mkl-psxe-2019.1-053 intel-mkl-tbb-rt-2019.1-144
  intel-mkl-tbb-2019.1-144 intel-psxe-common-doc-2019
  intel-psxe-common-2019.1-053 intel-mkl-64bit-2019.1-053
E: There were unauthenticated packages and -y was used without --allow-unauthenticated
I'm using following commands:
apt-key add GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB
sh -c 'echo deb https://apt.repos.intel.com/mkl all main > /etc/apt/sources.list.d/intel-mkl.list'
apt-get update
apt-get install -f --allow-downgrades --allow-remove-essential --allow-change-held-packages -y intel-mkl-64bit-2019.1-053
