7266 Discussions
AVX512 is slower than AVX2 when running CGESDD/SGESDD on Xeon Gold 6130
Ding__Jian
I am evaluating the performance of Intel MKL on Xeon Gold 6130 processors, which have two AVX512 FMA units. I see performance improvement with AVX512 for matrix multiplication and FFT. However, for matrix inversion, the performance of AVX512 is worse than AVX2. I tested complex float (CGESDD) and float (SGESDD).
My question is: what is the reason that cause the slowdown of AVX512 for CGESDD/SGESDD? Is it because these functions are not optimized for AVX512 or something I did wrong?
Below is the output when MKL_VERBOSE is enabled
MKL_VERBOSE Intel(R) MKL 2020.0 Product build 20191122 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) enabled processors, Lnx 2.10GHz lp64 sequential
I set MKL_ENABLE_INSTRUCTIONS to be AVX2 or AVX512 to compare their performance and set the library to be sequential.
For SGESDD/CGESDD, AVX2 outperforms AVX512 in most cases
64x64 matrix:
  • SGESDD: AVX2: 536.91us AVX512: 703.39us
  • CGESDD: AVX2: 766.52us AVX512: 861.09us
1000x1000 matrix:
  • SGESDD: AVX2: 305.60ms AVX512: 360.65ms
  • CGESDD: AVX2: 744.38ms AVX512: 696.96ms (AVX512 is slightly better)
For SGEMM/CGEMM, AVX512 outperforms AVX2
64x64 matrix:
  • SGEMM: AVX2: 8.58us AVX512: 7.08us
  • CGEMM: AVX2: 43.55us AVX512: 23.06us
1000x1000 matrix:
  • SGEMM: AVX2: 27.98ms AVX512: 18.40ms
  • CGEMM: AVX2: 109.17ms AVX512: 69.49ms
Ruqiu_C_Intel
Hello Ding, Jian,
Thank you for raising the topic! We will investigate the problem and back to here once there is any update.
One quick question is based on your test, the performance issue is exist in MKL 2020.0 or other version also has the same problem?
Ruqiu
Ding__Jian
Thanks Ruqiu. I have tested MKL 2019.0 as well and it has the same problem.
Best,
Jian
Gennady_F_Intel
Jian, yes, we see the same behavior with version 2020 and it looks like the code branch for this particular function is not well optimized. In the case, if this regression is important to you, I recommend submitting the problem via the official support channel - intel online service center against MKL product.
Gennady_F_Intel
Jian,
The time spent in xGESDD highly depends on the distribution of singular values.  Could you recheck the results by using exactly the same input matrix for calling ?GESDD on AVX2 and AVX512?
Gennady_F_Intel
Jian, have you tried to check the problem with the same inputs?
