About 【Image display of data】
XinyeChu
Situation: After reading local data and processing it with algorithms, I want to display my data results in the form of images. What library should I use (opencv/openngl/openswr, etc.), or how should I operate it? The desired image effect is as follows:
Gennady_F_Intel
Your questions is beyond of what Intel could suggest you. might be external tool/libs like Matplotlib, Plotly, Seaborn or etc. can help you with this case.
Gennady_F_Intel
