About MKL bidiagonal decomposition
Zhonghan_L_
Dear support team,
I met some problem when trying to run the ?unmbr() function from MKL, the bidiagonal terms could be calculated correctly, but I was unable to mutiply them back. Could you help me with it?
Thanks a lot!
float x_real[6 * 4] = { -0.57, -1.28, -0.39,  0.25,
    -1.93,  1.08, -0.31, -2.14,
     2.30,  0.24,  0.40, -0.35,
     1.93,  0.64, -0.66,  0.08,
     0.15,  0.30,  0.15, -2.13,
     0.02,  1.03, -1.43,  0.50};
int length[2] = { 4, 6 };
P = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*6*6, 32;
Q = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*6*6, 32);
TP = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8*6, 32);
TQ = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8*6, 32);
for (int j = 0; j < length[0] * length[1]; j++)
 Spec.real = x_real;
 Spec.imag = 0;
LAPACKE_cgebrd(LAPACK_ROW_MAJOR, length[1], length[0], Spec, length[0], s1, s2, TP, TQ); //here is correct
for (j = 0; j < length[1] * length[0] - 1; j++)
  P.real = Spec.real;
  P.imag = Spec.imag;
  Q.real = Spec.real;
  Q.imag = Spec.imag;
LAPACKE_cunmbr(LAPACK_ROW_MAJOR, 'Q', 'L', 'N', length[1], length[0], length[0], Q, length[0], TQ, S, length[1]);
LAPACKE_cunmbr(LAPACK_ROW_MAJOR, 'P', 'R', 'C', length[1], length[0], length[1], P, length[0], TP, S, length[1]);
Zhonghan_L_
When I use
( 0.96,-0.81) (-0.03, 0.96) (-0.91, 2.06) (-0.05, 0.41)
(-0.98, 1.98) (-1.20, 0.19) (-0.66, 0.42) (-0.81, 0.56)
( 0.62,-0.46) ( 1.01, 0.02) ( 0.63,-0.17) (-1.11, 0.60)
(-0.37, 0.38) ( 0.19,-0.54) (-0.98,-0.36) ( 0.22,-0.20)
( 0.83, 0.51) ( 0.20, 0.01) (-0.17,-0.46) ( 1.47, 1.59)
( 1.08,-0.28) ( 0.20,-0.12) (-0.07, 1.23) ( 0.26, 0.26)
as input, the output bidiagonal matrix
-3.08701   2.11257   0                 0
0               2.06604   1.26281      0
0               0               1.87313     -1.61263
0               0                0                2.00218
is also incorrect, the correct output should be
Diagonal
-3.0870 -2.0660 -1.8731 -2.0022
Super-diagonal
2.1126 -1.2628 1.6126
Zhen_Z_Intel
Hi Zhonghan,
I am afraid your code implementation is wrong. The bidiagonal matrix B just return as float array to s1 & s2 which s1 store diagonal elements, and s2 store super-diagonal. However, the ?unmbr is to calculate complex matrix C multiply with Q or P. I did not find any place you setting s1 &s2 to the real part of complex matrix S to computer S=S*Q, S=S*PH.
Fiona
Zhonghan_L_
Fiona Z. (Intel) wrote:
Hi Zhonghan,
Fiona
Hi Fiona,
Thanks for your response! I didn't attach whole part of the code, I did set s1 and s2, sorry for the confuse. As you said, the s1 and s2 consist the bidiagonal term, and in my another comment it also unable to yield the correct bidiagonal result when comes with the complex number. Also there was a little typo in my first post(which won't affect the output bidiagonal terms), the order of TP and TQ is mistaken, should be
LAPACKE_cgebrd(LAPACK_ROW_MAJOR, length[1], length[0], Spec, length[0], s1, s2, TQ, TP);
Zhonghan
Zhen_Z_Intel
Hi Zhonghan,
I do believe the result of MKL function is correct. Please follow below program:
#include <stdio.h>
#include <stdlib.h>
#include <mkl.h>
int main()
		0.96, -0.03, -0.91, -0.05,
		-0.98, -1.20, -0.66, -0.81,
		0.62, 1.01, 0.63, -1.11,
		-0.37, 0.19, -0.98, 0.22,
		0.83, 0.20,-0.17, 1.47,
		1.08, 0.20, -0.07, 0.26};
	float x_imag[6*4] = {
		-0.81, 0.96, 2.06, 0.41,
		1.98, 0.19, 0.42, 0.56,
		-0.46, 0.02,-0.17, 0.60,
		0.38,-0.54,-0.36,-0.20,
		0.51, 0.01,-0.46, 1.59,
		-0.28,-0.12, 1.23, 0.26};
	MKL_Complex8* P = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*4*4, 32);
	MKL_Complex8* Q = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*6*6, 32);
	MKL_Complex8* TP = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*4, 32);
	MKL_Complex8* TQ = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*4, 32);
	MKL_Complex8* Spec = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*4*6,32);
	MKL_Complex8* S = (MKL_Complex8*)MKL_malloc(sizeof(MKL_Complex8)*6*4,32);
	float s1[4];
	float s2[3];
	 Spec.real = x_real;
	 Spec.imag = x_imag;
	LAPACKE_cgebrd(LAPACK_ROW_MAJOR, length[1], length[0], Spec, length[0], s1, s2, TQ, TP); //here is correct
	printf("Matrix C:\n");
	for(int i=0;i<length[1];i++)
		for(int j=0;j<length[0];j++)
			S[i*length[0]+j].real=0;
			S[i*length[0]+j].imag=0;
			if(i==j)
				S[i*length[0]+j].real=s1;
			else if(j-i==1)
				S[i*length[0]+j].real=s2[j-1];
			printf("%f+%fi\t",S[i*length[0]+j].real,S[i*length[0]+j].imag);
		printf("\n");
	LAPACKE_cunmbr(LAPACK_ROW_MAJOR, 'Q', 'L', 'N', length[1], length[0], length[0], Spec, length[0], TQ, S, length[0]);
	LAPACKE_cunmbr(LAPACK_ROW_MAJOR, 'P', 'R', 'C', length[1], length[0], length[1], Spec, length[0], TP, S, length[0]);
	printf("real part of Q*C*P':\n");
		for(int k=0;k<length[0];k++)
			printf("%f\t", S[i*length[0]+k].real);
		printf("\n");
	printf("\nimag part of Q*C*P':\n");
			printf("%f\t", S[i*length[0]+k].imag);
		printf("\n");
	return 0;
The matrix A can get by multiplied back by using ?unmber function.
Fiona
Zhen_Z_Intel
Another point is about the result of bidiagonal matrix B. The result of factorization would not be the only. For example, 1 can be factorized as 1*1, also can be -1*-1, it is depends on the algorithm of factorization. If you get the result with different sign, that means the elements in Q or PH maybe also different. It would be fine the results only with different sign. You could use ?ungbr to generate Q and P to check.
