Affinity Issues with Core i7
hpc-matt
Greets everyone,
I am writing some C Code using MKL to run on a dual socket Core i7 Alienware machine. I have installed Ubuntu 9.04, and when I go to change the affinity, (using KMP_AFFINITY), it only sees one package, 4 cores, 2 threads per core.
How can I change the affinity to reflect 2 packages, 4 cores each, 1 thread per core? I know that I can shut off hyper threading in the bios, and am wiling ot do so, but how can I get the multiple packages to show up?
Thanks in advance!
hpc-matt
Ying_H_Intel
Hi Hpc-matt,
I search in the forum, there are some discussion, like http://software.intel.com/en-us/forums/topic/296195, http://software.intel.com/en-us/forums/topic/294973.
It may be a known bug. as the thread 294973. Could you please let us know some details, like
1. what mkl version
2. what function, what library are used
3. what value of KMP_AFFINITY
Generally, by default , the OMP thread of MKL should be able to see the two packages. and run on 8 threads on each core.
Anyway, could you please do a test on your machine
>export KMP_AFFINITY=verbose,granularity=fine,compact,1,0
and let us know the result?
Ying
