7298 Discussions
An error occurred while using "Parallel" in "Use oneMKL", displaying kernelbase.pdb not loaded.
CloudShadow
An error occurred while testing cblas_dgemm which using "Parallel" in "Use oneMKL" on Visual Studio 2022,   
But there is no such issue when selecting "sequential". 
VarshaS_Intel
Could you please provide us with the complete sample reproducer code and matrix (or) complete project file you are using to reproduce your issue at our end?
And also, as these forums are intended to support the English language, could you please translate and provide us with the error that you are getting in the English language?
Thanks & Regards,
Varsha
CloudShadow
Test code is completely copied from the website Multiplying Matrices Using dgemm (intel.com).
After adjusting the visual studio language to English, the screenshots are
and
VarshaS_Intel
Thanks for providing the details.
We are able to run successfully without any error. Could you please find and try the below screenshot for the properties of setting Intel MKL in Visual Studio 2022 and let us know if you are still facing an error?
And also, could you please try the sample code on the Intel oneAPI Command Prompt and let us know if you are still facing any errors?
If possible, please repair your Intel oneAPI toolkit with Microsoft Visual Studio for complete proper integration.
Thanks & Regards,
Varsha
CloudShadow
Thank you for your prompt attention.
I found that the reason for the error was that the libiomp5md.dll was not loaded, so I modified the Working Directory so that Visual Studio could search for it.
1AYGV]MJY110YY@FS3K96U7.png1AYGV][email protected]
The code can now run correctly, as shown in the screenshot.
Thanks for your response again.  The problem has been resolved.
VarshaS_Intel
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Have a Good Day!
Thanks & Regards,
Varsha
