Big Performance Problem with PARDISO 2018 Update 3
Göttinger__Michael
Hello folks,
I've a strange performance problem with PARDISO on Windows. Before I open a support call I'll hope to get some feedback in this forum.
I'm using Intel® Parallel Studio XE 2018 Update 3 Composer Edition for Fortran Windows*, Version 18.0.0040.
I have noticed that parallel processing in PARDISO in MKL version 2018.0.3 does not work at all and processing with only one thread is significantly slower than in version 2016.
Attached I've a small C++ test program and sample data to solve a small system multiple time.
When I run the program using the MKL DLLs from version 2018.0.3 I get following result:
>Release\pardiso.exe _data\mat.mm _data\b.mm
Intel(R) Math Kernel Library Version 2018.0.3 Product Build 20180406 for 32-bit applications
Solving matrix file _data\mat.mm with vector data _data\b.mm.
Data: rows=445, cols=445, values=1339
MKL threads: 6
Performance: Loops=10000, Time=2.785514 sec
And now the funny stuff starts. The same program executed with MKL DLLs from version 2016 (11.3.3) create the following result:
Intel(R) Math Kernel Library Version 11.3.3 Product Build 20160413 for 32-bit applications
MKL threads: 6
Performance: Loops=10000, Time=1.171534 sec
And it's gonna get worse. The new PARDISO version 2018.0.3 uses a big amount of CPU time for multiple threads but it is slower compared with execution with only one single thread!
According to my understanding I've configured all stuff correct. And as it can be seen, using the old MKL stuff from 2016 it works fine.
Göttinger__Michael
For better understanding I have attached log files containing PARDISO diagnostic data. It shows results from single and multicore runs. This also makes it clear that 6 threads are really used and at the same time the performance of MFLOPS decreases.
This is the result form 6 core parallel calculation:
Statistics:
Parallel Direct Factorization is running on 6 OpenMP
< Linear system Ax = b >
             number of equations:           445
             number of non-zeros in A:      1339
             number of non-zeros in A (%): 0.676177
             number of right-hand sides:    1
< Factors L and U >
             number of columns for each panel: 128
             number of independent subgraphs:  0
< Preprocessing with state of the art partitioning metis>
             number of supernodes:                    427
             size of largest supernode:               2
             number of non-zeros in L:                1153
             number of non-zeros in U:                672
             number of non-zeros in L+U:              1825
             gflop   for the numerical factorization: 0.000015
             gflop/s for the numerical factorization: 0.000479
Matrix Performance: Loops=1 Time=0.182937 sec
Here comes now the single core result. It has a better gflop/s performance as using MKL with 6 cores:
Statistics:
Parallel Direct Factorization is running on 1 OpenMP
< Factors L and U >
             gflop/s for the numerical factorization: 0.000532
Matrix Performance: Loops=1 Time=0.164001 sec
Gennady_F_Intel
the problem size is too small. Do you see the similar performance regression with biggestt problem size too?
Göttinger__Michael
In my real application I can see same performance problem with larger systems too.
Anyway, I'll verify it in the small test program too. Please feel free to use my attached sample and any MM data file to verify it which a larger data set to be solved.
The main problem for me is that it seems to be 3 times slower in MKL 2018 as it was in MKL 2016. I'm happy to get feedback about compiler options and other settings which can be changed to get better PARDISO performance in MKL 2018 (or at least the same one as it was in the past).
LRaim
I am interested in the performance of Pardiso for systems with a number of equations around 500.
So possible solutions are: a) do not use pardiso for sparse systems with N<nnn. b)  use pardiso but set max no of cores to 1.  c) ......
Best regards
Göttinger__Michael
As mentioned in my previous post, I've done a test with a little bit larger matrix to be solved. Now the matrix is 131458x131458 with 712722 non-zero values. This is the typical size for our application.
The same performance problem in MKL 2018 is here too:
>Release\pardiso.exe _data\mat2.mm _data\b2.mm
Solving matrix file _data\mat2.mm with vector data _data\b2.mm.
Data: rows=131458, cols=131458, values=712722
MKL threads: 6
Performance: Loops=100, Time=8.250383 sec
Same system solved with MKL 2016:
MKL threads: 6
Performance: Loops=100, Time=4.823882 sec
As you can clearly see, the new MKL 2018 it about 50% slower as older versions.
Andrew_Smith
Valued Contributor I
I recently did the same upgrade in versions. I see a similar downgrade in run times, BUT it now gives better accuracy on my ill conditioned matrices and now matches IMSL and SuperLU in this respect. It was quite poor before and accuracy is as important to me as the speed.
I cannot say anything about multi-core as I long gave up on that aspect of PARDISO. But it might be worth another look now.
My problem sizes are between 500 and 20000 freedoms.
Gennady_F_Intel
thanks Andrew and Michael. I managed to reproduced the issue on our side and the case is escalated. we will keep you updated with the status.
Beccaria__Massimilia
Dears,
has this issue in PARDISO been fixed in any of the more recent releases of MKL?
Thanks and kind regards
Dears,
Is it possible to have an update on this?
