7258 Discussions
Bug in xggsvd? "Parameter 5 was incorrect on entry to DORMQR"
Andreas_Jensen
When running the program in single threaded mode I get the error message "Parameter 5 was incorrect on entry to DORMQR". The message is not present if I either run the program with multiple threads or if I compile it with reference LAPACK. My compiltervar settings are intel64 ilp64 and the program is compiled with
ifort testgsvd.f90 -lmkl_rt
testgsvd.f90:
program testgsvd
  implicit none
  integer*8 :: k, l, alpha(10), beta(10), iwork(20), info
  double precision :: A(10,20), B(10,20), U, V, Q, work(80)
  open(1, file="a.txt", action = "read")
  read(1, *) A
  open(2, file="b.txt", action = "read")
  read(2, *) B
  close(1)
  close(2)
  call dggsvd('N', 'N', 'N', 10_8, 20_8, 10_8, k, l, A, 10_8, B, 10_8, alpha, beta, U, 1_8, V, 1_8, Q, 1_8, work, iwork, info)
end program testgsvd
The matrices A and B are attached.
Gennady_F_Intel
by another words, the issue exists when you link with sequential mode of MKL?
the example contains the ?ggsvd, but the title is about domgr.
why parameter info is INTEGER* 8?
when you link with mkl_rt - you use LP64 interface by the default.
Andreas_Jensen
Thanks for the fast reply.
No. The difference is just between
./a.out
and
OMP_NUM_THREADS=1 ./a.out
Yes. The call is to dggsvd, but the error message comes from dormqr. I can see that reference LAPACK doesn't even call that function so thats the reason why I suspect it to be an MKL problem.
Before I compile and execute, I run source PATHTOINTEL/bin/compilervars.sh intel64 ilp64 and I thought that would cause ilp64 mode when running programs linked with lmkl_rt. Since you asked, I've also tried to set export MKL_INTERFACE_LAYER=ilp64 but I still get the same error.
Gennady_F_Intel
Ok, thanks Andreas. I see the similar behaviour on my side too. we will check the cause of the problem.
