C interface for LAPACK routines?
ltkeene
Hello all, I've downloaded a trial verison of the latest release of MKL but find the documentation very disjointed and confusing. At the moment I simply need to solve a small (3x3) system of linear equations. Is there a C interface for the LAPACK routines (where I assume I find this functionality)? The documentation only talks about Fortran.
Thank you in advance.
Gennady_F_Intel
Yes, the documentation only talks only about Fortran, because of there are no special C interface, but you can use Fortran interface from C code.
As an example please look at the Forum question ( http://software.intel.com/en-us/forums/showthread.php?t=61117)where MKL customer call dgesvx rountine from C code.
--Gennady
TimP
Quoting - ltkeene
You could use the Clapack interface with MKL, if that is your question. MKL would be an inefficient way to work with such a small system anyway. As MKL BLAS is a work-alike implementation of the public netlib BLAS, the public documentation applies.
Gennady_F_Intel
As an additional info:
CLapack intefaces you find into mkl_lapack.h, but as I said
MKL documentation contains only Fortran interface description. As an example the function for computes the solution to the system of linear equations with a square matrix A and multiple right-hand sides, and provides error bounds on the solution.
//mkl_lapack.h
//void dgesvx( char *fact, char *trans, MKL_INT *n, MKL_INT *nrhs, double *a, MKL_INT *lda, double *af, MKL_INT *ldaf, MKL_INT *ipiv, char *equed, double *r, double *c, double *b, MKL_INT *ldb, double *x, MKL_INT *ldx, double *rcond, double *ferr, double *berr, double *work, MKL_INT *iwork, MKL_INT *info );
But all parameters of this function you can find into MKL manual for Fortran 77 or F95:
//Fortran 77
//call dgesvx( fact, trans, n, nrhs, a, lda, af, ldaf, ipiv, equed, r, c, b, ldb, x, ldx, rcond, ferr, berr, work, iwork, info )
Gennady
Gennady_F_Intel
Hello. please pay attention on the topic
Todd posted yesterday about C interface for LAPACK routines.
Please send your recomendations to Michael and Creg about that.
--Gennady
