CBLAS level 3 routine problem
stanleyimko
Hi, all. I would like to use the BLAS routine dgemm to do matrix multiplication. I made a testing program and compared the results of CBLAS and BLAS. I am confused that CBLAS produced a wrong result. I check from time to time but still don't know where goes wrong. Can anyone give me some suggestion? The code and results are pasted below. Thanks in advance.
int main()
const int n = 3, m = 2;
double A, B;
double d[n*m], e[n*m];
two dimension storage:
A = 1, 2 B = 1, 1
2, 3 1, 1
3, 4 1, 1
for( int i = 0; i < n; i++ )
for( int j = 0; j < m; j++ ){
A = i+j+1;
B = 1;
one dimension storage
with column-major:
d = {1, 2, 3, 2, 3, 4}
e = {1, 1, 1, 1, 1, 1}
for( int i = 0; i < n; i++ ){
d[j*n+i] = A;
e[j*n+i] = B;
Call dgemm:
C := alpha*op(A)*op(B) + beta*C
/************CBLAS***************/
CBLAS_ORDER order;
order = CblasRowMajor; //specify row major
CBLAS_TRANSPOSE transa;
transa = CblasTrans; // transpose A
CBLAS_TRANSPOSE transb;
transb = CblasNoTrans;
int lda = n; //the first dimension of A
int ldb = n; //the first dimension of B
int ldc = m; //the first dimension of C
double alpha = 1.0, beta = 0.0;
double C;
cblas_dgemm( order, transa, transb, m, m, n,
alpha, *A, lda, *B, ldb, beta, *C, ldc);
for( int i = 0; i < m; i++ ){
cout << C << ", ";
cout << endl;
/*********direct Fotran call*********/
double f[m*m];
char transaa = 'T';
char transbb = 'N';
dgemm( &transaa, &transbb, &m, &m, &n,
α, d, &lda, e, &ldb, β, f, &ldc);
cout << endl;
for( int i = 0; i < m*m; i++ )
cout << f << ", ";
cout << endl;
return 0;
Result:
5, 6,
6, 7,
6, 9, 6, 9,
Murat_G_Intel
The leading dimensions for the CBLAS call are set incorrectly. For the row-major matrix format, the leading dimensions should stride rows of the matrix. Since your 2D arrays are A[m] and B[m], lda and ldb should be m. Please see themodified code below:
[cpp]    CBLAS_ORDER order;
    int lda = m; //modified leading dimension for A
    int ldb = m; //modified leading dimension for B
[/cpp]
Then, before the FORTRAN dgemm call, we need to reset lda and ldb to n since the FORTRAN call is in column-major format.
[cpp]    /*********direct Fotran call*********/
    lda = n; //reset the leading dimension of A
    ldb = n; //reset the leading dimension of B
    double f[m*m];
    char transaa = 'T';
    char transbb = 'N';
            α, d, &lda, e, &ldb, β, f, &ldc);[/cpp]
After these modifications, I get same results from CBLAS and FORTRAN dgemm:
Result:
6, 6,
9, 9,
6, 9, 6, 9,
Best wishes,
Efe
Murat_G_Intel
[/cpp]
    double f[m*m];
    char transaa = 'T';
    char transbb = 'N';
Result:
6, 6,
9, 9,
6, 9, 6, 9,
Best wishes,
Efe
stanleyimko
Efe,
Thanks so much. I am kind of misunderstanding the dimension stuff. I should check carefully before posting the thread next time.
Stanley
