Call cblas_dsymv from c#
Yang76
I try to upgrade the mkl library in our C# applications. After upgrading to version 2025.2, most APIs work fine, such as cblas_dgemm. However, the cblas_dsymv call fails with error “Indirect call guard check detected invalid control transfer”.
I use the dlls from the redist package and import mkl_rt.2.dll.
Interestingly, if I switch to the version 2024.1, the cblas_dsymv call works.
Fengrui
Thank you for reporting this issue!
It has been fixed and the fix will be included in the oneMKL 2025.3 release.
