7298 Discussions
MKL static link in Microsoft Visual C/C++ projects
RM2025
Hi Intel Community,
I have a C++ Console App project in MVS 2022 where I call the dgetrf_ method.
I would like to statically link the MKL libraries without using the Project>Properties>Configuration Properties>Intel Libraries for oneAPI settings.
I selected the following settings in the Project>Properties>Configuration Properties section:
  • C/C++>General>Additional Include Directories: ..\MKL\include;
  • Linker>General>Additional Library Directories: ..\MKL\StaticLib;
  • Linker>Input>Additional dependencies: mkl_core.lib;mkl_sequential.lib;mkl_intel_ilp64.lib;mkl_lapack95_ilp64.lib;mkl_blacs_intelmpi_ilp64.lib;mkl_blas95_ilp64.lib;mkl_cdft_core.lib;mkl_sycld.lib;
And the project was successfully built, but the dgetrf_ method returned -1 instead of 0 (= success).
If I build the project with the following settings of the Project>Properties>Configuration Properties>Intel Libraries for oneAPI>Intel oneAPI Math Kernel Library section:
  • Use oneMKL: Sequential
  • Use ILP64 interfaces: Yes
  • Use MPI Library: Intel MPI Library
The dgetrf_ method is successfully executed.
Could someone help me to understand what is my mistake?
I'm using the MKL libraries version 2024.2. I have attached my solution.
Thank you,
MR2025
Fengrui
It looks MKL\StaticLib is empty.
