7297 Discussions
Can I use SCALAPACK library on the single machine (Xeon)?
Dan_Ghiocel
Hi, All Experts,
      I'm wondering if I can use ScaLapack library on a single machine, since Scalapack is for distributed arch. If it is possible, would you please tell me how to set up the running environment?
     Thanks a lot.
     Dan
Ying_H_Intel
Hi Dan,
Yes, you can run scalapack on one singe machine as scalapack is based on MPI, which allow run on single machines or multiple machine.
If you have installed Intel parallel Studio Cluster edition and MPI (intel MPI or other open source MPI),
Here is one c scalapack sample and step by step environment setting for your reference
https://software.intel.com/en-us/articles/using-cluster-mkl-pblasscalapack-fortran-routine-in-your-c-program/
and you can refer to MKL userguide for further information.
Ying H.
Intel MKL Consulting
Dan_Ghiocel
Thanks for your help. I'm going to try.
Dan
