7227 Discussions
Can't compute 1D discrete sine transforms of size >=INT_MAX
Keipert__Kristopher
n=INT_MAX: Intel MKL TRIG TRANSFORMS ERROR: Fatal error (error message=Intel MKL DFTI ERROR: Inconsistent configuration parameters
n=INT_MAX-1: Finishes fine
n=INT_MAX+1: Segmentation fault
I am using ILP64. Tracking through the FFTW interface, I I know the segfault occurs in s_init_trig_transform().
Compile line:
icc transform.cpp -std=c++11 -O3 -DMKL_ILP64 -xcore-avx2 -I${MKLROOT}/include/fftw -L${MKLROOT}/lib/intel64 -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -ldl -qopenmp
Minimal reproducible example:
#include <fftw3.h>
#include <fftw3_mkl.h>
#include <random>
#include <omp.h>
int main()
  MKL_INT n = 2147483647; //INT_MAX
  fftwf_init_threads();
  float* inout = (float*)fftwf_malloc(sizeof(float)*n);
  //Initialize inout array with random values
  std::random_device rd;
  std::mt19937 gen(rd());
  std::uniform_real_distribution<float> dist(0.0f, 1.0f);
  #pragma omp parallel for
  for (size_t i=0; i<n; ++i) {
    inout =  dist(gen);
  //FFTW Guru parameters
  const fftwf_r2r_kind kind = FFTW_RODFT00;
  int rank=1;
  int howmany_rank=0; //Not used by MKL
  fftwf_iodim64* howmany_dims; //Not used by MKL
  fftwf_iodim64* dims = (fftwf_iodim64*)fftwf_malloc(rank*sizeof(fftwf_iodim64));
  dims[0].n=n;
  dims[0].is=1;
  dims[0].os=1;
  fftwf_plan_with_nthreads(omp_get_max_threads());
  //in-place real-to-real sine transform
  fftwf_plan p = fftwf_plan_guru64_r2r(rank, dims, howmany_rank, howmany_dims, inout, inout, &kind, FFTW_MEASURE);
  fftwf_execute(p);
  fftwf_destroy_plan(p);
  fftwf_free(inout);
  fftwf_cleanup_threads();
  return 0;
Khang_N_Intel
Hi Kristopher,
I have already provided the answer to this inquiry in the online service center since you and Kalyan opened a ticket there for this same problem.  I believe that Kalyan already communicated the answer to you.  Therefore, we are going to close this thread.
Should you have further questions, please do not hesitate to contact us.
Khang
Khang_N_Intel
Hi Kristopher,
This behavior is documented here.
