Conjugate Gradient source Code Example
Juan_Diego_E_
Good afternoon,
I would like to have some help in the process of linking MKL with Visual Studio in Fortran Language. I am trying to run the example "cg_jacobi_precon" that comes in the Intel Folder, but I have not succeed. I am actually using F90. Can I have any advice, please, on which source codes do I need to include in my project as well as header files, and if I have to set any address in the Fortran and/or Linker properties of the project?
Please find below the actual example (I guess it is in F77) from Intel.
Thank you.
JD.
!                              INTEL CONFIDENTIAL
!   Copyright(C) 2005-2010 Intel Corporation. All Rights Reserved.
!   The source code contained  or  described herein and all documents related to
!   the source code ("Material") are owned by Intel Corporation or its suppliers
!   or licensors.  Title to the  Material remains with  Intel Corporation or its
!   suppliers and licensors. The Material contains trade secrets and proprietary
!   and  confidential  information of  Intel or its suppliers and licensors. The
!   Material  is  protected  by  worldwide  copyright  and trade secret laws and
!   treaty  provisions. No part of the Material may be used, copied, reproduced,
!   modified, published, uploaded, posted, transmitted, distributed or disclosed
!   in any way without Intel's prior express written permission.
!   No license  under any  patent, copyright, trade secret or other intellectual
!   property right is granted to or conferred upon you by disclosure or delivery
!   of the Materials,  either expressly, by implication, inducement, estoppel or
!   otherwise.  Any  license  under  such  intellectual property  rights must be
!   express and approved by Intel in writing.
!  Content: Intel MKL RCI (P)CG Fortran-77 example
!  Example program for solving symmetric positive definite system of equations.
!  Full case: full functionality of RCI (P)CG is used.
      PROGRAM rci_pcg_f77_test_3
      IMPLICIT NONE
      INCLUDE 'mkl_rci.fi'
! Define arrays for the upper triangle of the coefficient matrix and
! preconditioner as well as an array for rhs vector
! Compressed sparse row storage is used for sparse representation
      INTEGER N, RCI_request, itercount, expected_itercount, i
      PARAMETER (N=8)
      PARAMETER (expected_itercount=8)
      DOUBLE PRECISION  rhs(N)
      INTEGER IA(9)
      INTEGER JA(18)
      DOUBLE PRECISION A(18)
! Fill all arrays containing matrix data.
      DATA IA /1,5,8,10,12,15,17,18,19/
      DATA JA
     1 /1,  3,     6,7,
     2    2,3,   5,
     3      3,         8,
     4         4,    7,
     5           5,6,7,
     6             6,  8,
     7               7,
     8                 8/
      DATA A
     1 /7.D0,      1.D0,           2.D0, 7.D0,
     2       -4.D0, 8.D0,     2.D0,
     3             1.D0,                      5.D0,
     4                  7.D0,      9.D0,
     5                       5.D0, 1.D0, 5.D0,
     6                            -1.D0,      5.D0,
     7                                  11.D0,
     8                                        5.D0/
! Allocate storage for the solver ?par and the initial solution vector
      INTEGER length
      PARAMETER (length=128)
      INTEGER ipar(length)
      DOUBLE PRECISION dpar(length),TMP(N,4)
! Some additional variables to use with the RCI (P)CG solver
      CHARACTER MATDES(3)
      DOUBLE PRECISION  solution(N)
      DOUBLE PRECISION expected_sol(N)
      DATA expected_sol/1.D0, 0.D0, 1.D0, 0.D0, 1.D0, 0.D0, 1.D0, 0.D0/
      DOUBLE PRECISION  ONE
      DATA   ONE/1.D0/
      DOUBLE PRECISION DNRM2, Euclidean_norm, temp(N)
      EXTERNAL DNRM2
! Initialize the right hand side through matrix-vector product
       CALL MKL_DCSRSYMV('U', N, A, IA, JA, expected_sol, rhs)
! Initialize the initial guess
       DO I=1, N
         solution(I)=0.D0
       ENDDO
       MATDES(1)='D'
       MATDES(2)='L'
       MATDES(3)='N'
! Initialize the solver
      CALL dcg_init(N, solution,rhs, RCI_request,ipar,dpar,TMP)
      IF (RCI_request .NE. 0 ) GOTO 999
! Set the desired parameters:
! INTEGER parameters:
! set the maximal number of iterations to 100
! LOGICAL parameters:
! run the Preconditioned version of RCI (P)CG with preconditioner C_inverse
! DOUBLE PRECISION parameters
      ipar(5)=100
      ipar(11)=1
! Check the correctness and consistency of the newly set parameters
      CALL dcg_check(N,solution,rhs,RCI_request,ipar,dpar,TMP)
! Compute the solution by RCI (P)CG solver
! Reverse Communications starts here
1     CALL dcg(N,solution,rhs,RCI_request,ipar,dpar,TMP)
! If RCI_request=0, then the solution was found according to the requested
! stopping tests. In this case, this means that it was found after 100
! iterations.
      IF (RCI_request .EQ. 0) THEN
          GOTO 700
! If RCI_request=1, then compute the vector A*TMP(:,1)
! and put the result in vector TMP(:,2)
      ELSEIF (RCI_request .EQ. 1) THEN
        CALL MKL_DCSRSYMV('U', N, A, IA, JA, TMP, TMP(1,2))
        GOTO 1
! If RCI_request=2, then do the user-defined stopping test: compute the
! Euclidean norm of the actual residual using MKL routines and check if
! it is less than 1.D-8
      ELSEIF (RCI_request .EQ. 2) THEN
        CALL MKL_DCSRSYMV('U', N, A, IA, JA, solution, temp)
        CALL DAXPY(N,-1.D0,rhs,1,temp,1)
        Euclidean_norm = DNRM2(N,temp,1)
        IF (Euclidean_norm .GT. 1.D-8) THEN
! The solution has not been found yet according to the user-defined stopping
! test. Continue RCI (P)CG iterations.
          GOTO 1
        ELSE
! The solution has been found according to the user-defined stopping test
          GOTO 700
        END IF
! If RCI_request=3, then compute apply the preconditioner matrix C_inverse
! on vector TMP(:,3) and put the result in vector TMP(:,4)
      ELSEIF (RCI_request .EQ. 3) THEN
        CALL MKL_DCSRSV('N', N, ONE, MATDES,
     &             A, JA, IA, IA(2), TMP(1,3), TMP(1,4))
        GOTO 1
      ELSE
! If RCI_request=anything else, then dcg subroutine failed
! to compute the solution vector: solution(N)
        GOTO 999
      ENDIF
! Reverse Communication ends here
! Get the current iteration number
700   CALL dcg_get(N,solution,rhs,RCI_request,ipar,dpar,TMP,
     &             itercount)
! Print solution vector: solution(N) and number of iterations: itercount
      WRITE(*, *) ' The system has been solved '
      WRITE(*, *) ' The following solution obtained '
      WRITE(*,800) (solution(i),i =1,N)
      WRITE(*, *) ' expected solution '
      WRITE(*,800)(expected_sol(i),i =1,N)
800   FORMAT(4(F10.3))
      WRITE(*,900)(itercount)
900   FORMAT(' Number of iterations: ',1(I2))
      DO I=1,N
         expected_sol(I)=expected_sol(I)-solution(I)
      ENDDO
      Euclidean_norm=DNRM2(N,expected_sol,1)
! Release internal MKL memory that might be used for computations
! NOTE: It is important to call the routine below to avoid memory leaks
! unless you disable MKL Memory Manager
      CALL MKL_FREEBUFFERS
      IF (itercount.EQ.expected_itercount .AND.
     1                                   Euclidean_norm.LE.1.0D-12) THEN
         WRITE( *,'(A,A)') 'This example has successfully PASSED',
     1 ' through all steps of computation!'
         STOP 0
      ELSE
         WRITE( *,'(A,A,A,I5,A,A,A,E12.5,A)') 'This example may have',
     1 ' FAILED as either the number of iterations differs from the',
     2 ' expected number of iterations ',expected_itercount,' or the',
     3 ' computed solution differs much from the expected solution (',
     4 'Euclidean norm is ',Euclidean_norm,'), or both.'
         STOP 1
      ENDIF
999   WRITE( *,'(A,A)') 'This example FAILED as the solver has',
     1 ' returned the ERROR code', RCI_request
      STOP 1
      END
mecej4
Here is one possible source of error: you apparently are comparing solutions for linear equations with a symmetric indefinite matrix. In the GMRES version of your code, you initialize the (rowidx, col, val) arrays for the upper triangular part of the matrix. The solver routines that you call, however, expect the lower triangular part to be filled in, as well, because these routines (with names containing GE rather than SYM) have to work with unsymmetric matrices too. In effect, then, the Pardiso version gives the solution for the symmetric matrix whereas the GMRES version gives the solution for an upper triangular, unsymmetric matrix. Naturally, the two solutions will not agree.
Juan_Diego_E_
Good afternoon,
I just wanted to clarify that I managed to run the code (I had a typo in one of the lines).
I would also like to ask out there, if FGMRES MKL subroutine is threaded or not? (let say the example that comes with the ILU0 preconditioner, how can I run it in parallel?). If it is not threaded, I would like to have any advice on how can I use OpenMP or any compiler options (from Visual Studio Properties) to parallelize this FGMRES subroutine. I am solving a finite difference problem with multiple time steps, therefore I have to call a lot of times a subroutine that itself calls DFMGRES (like in the script above).
Thank you very much in advance.
J.D.
Gennady_F_Intel
both Preconditioners  (ILUT and IL0) from MKL are not threaded
