Create 8 VSLStreamStatePtr affected MKL "dtrsm"' s performance, include test code,issue still open
jian_l_1
At first I want to generate random in multythreads in the following code:
#define nstreams 8
VSLStreamStatePtr stream[nstreams];
int k;
for ( k=0; k< nstreams; k++ )
vslNewStream( &stream, VSL_BRNG_MT2203+k, seed );
But I found, If I generate 8 VSLStreamStatePtr , other MKL functions performance will be affected(5 times slower then normal), these affected funtions are:
dtrsm("Right", "Upper", "No transpose", "Nunit", ...);
Gennady_F_Intel
The root cause analysis shows the problem  with internal mkl_serv_allocate() routine. The issue is escalated. We will keep you updated with the status of this issue!
Zhen_Z_Intel
Hi jian,
Here's some question about your issue:
1. How did you test the performance? If you enable MKL_VERBOSE to check, or write program to get clock time?
2. How about your problem size for trsv, gemv and trsm? and what about your seed for random data generation? Could you please provide a reproducer (just a sample case) that we can investigate?
Fiona
jian_l_1
Hi, Fiona
Thanks for your response.
I need modify the issue: ONLY dtrsm is affected by new 8 vslNewStream.
Here is test code and result in my machine:
result:
Before new 8 VSLStreamStatePtr time: 1
After new 8 VSLStreamStatePtr time: 12
Code (c++):
#include "mkl_vsl_functions.h"
#include "mkl_vsl_defines.h"
#include "mkl_blas.h"
#include "mkl_service.h"
int MmatrixARows=26;
int NmatrixBColumns=3;
double alpha=1;
int ldm=29;
double matrixA[87]={0.00311007,-1.12899e-05,-0.000141499,-1.82698e-14,-0.000785694,-1.98974e-14,-0.000778519,-2.71811e-14,-2.29056e-14,-2.7844e-14,-2.24393e-14,-3.12059e-14,-1.26095e-14,-4.47909e-10,-7.97785e-19,-1.74566e-07,-4.15789e-10,-2.17286e-29,-1.56053e-10,-1.34911e-12,-2.19906e-27,-3.5138e-09,-1.0398e-07,-5.29274e-06,-4.9252e-07,-8.93104e-05,-3.71938e-05,-1.28896e-09,-1.17735e-07,-3.26114e-08,0.00289051,-0.000149547,-2.34128e-13,-1.92531e-13,-0.000706043,-2.17513e-13,-3.48327e-13,-0.000670723,-3.56823e-13,-2.8756e-13,-3.99905e-13,-1.61591e-13,-5.73997e-09,-2.17241e-19,-1.42301e-08,-5.32835e-09,-5.47231e-30,-8.81321e-10,-3.39771e-13,-5.53829e-28,-8.70999e-10,-2.05336e-08,-5.30965e-06,-4.83782e-07,-8.84461e-05,-3.73614e-05,-1.5481e-11,-1.15641e-07,-4.02283e-07,-4.25622e-07,0.00303418,-0.00079269,-2.05185e-13,-2.71747e-13,-2.3181e-13,-0.000797297,-3.1283e-13,-3.80276e-13,-3.06461e-13,-4.2619e-13,-1.72212e-13,-6.11725e-09,-1.91907e-19,-1.90223e-07,-5.67858e-09,-4.75132e-30,-1.02734e-09,-2.95006e-13,-4.80861e-28,-5.38704e-10,-1.5342e-08,-1.98894e-06,-6.03159e-06,-8.35693e-05,-4.29327e-05,-1.62871e-10,-1.44174e-06};
double matrixB_ori[87]={-1.82698e-14,-0.000785694,-1.98974e-14,-0.000778519,-2.71811e-14,-2.29056e-14,-2.7844e-14,-2.24393e-14,-3.12059e-14,-1.26095e-14,-4.47909e-10,-7.97785e-19,-1.74566e-07,-4.15789e-10,-2.17286e-29,-1.56053e-10,-1.34911e-12,-2.19906e-27,-3.5138e-09,-1.0398e-07,-5.29274e-06,-4.9252e-07,-8.93104e-05,-3.71938e-05,-1.28896e-09,-1.17735e-07,-3.26114e-08,0.00289051,-0.000149547,-2.34128e-13,-1.92531e-13,-0.000706043,-2.17513e-13,-3.48327e-13,-0.000670723,-3.56823e-13,-2.8756e-13,-3.99905e-13,-1.61591e-13,-5.73997e-09,-2.17241e-19,-1.42301e-08,-5.32835e-09,-5.47231e-30,-8.81321e-10,-3.39771e-13,-5.53829e-28,-8.70999e-10,-2.05336e-08,-5.30965e-06,-4.83782e-07,-8.84461e-05,-3.73614e-05,-1.5481e-11,-1.15641e-07,-4.02283e-07,-4.25622e-07,0.00303418,-0.00079269,-2.05185e-13,-2.71747e-13,-2.3181e-13,-0.000797297,-3.1283e-13,-3.80276e-13,-3.06461e-13,-4.2619e-13,-1.72212e-13,-6.11725e-09,-1.91907e-19,-1.90223e-07,-5.67858e-09,-4.75132e-30,-1.02734e-09,-2.95006e-13,-4.80861e-28,-5.38704e-10,-1.5342e-08,-1.98894e-06,-6.03159e-06,-8.35693e-05,-4.29327e-05,-1.62871e-10,-1.44174e-06,-1.87786e-13,-2.49161e-13,-0.00079269};
double matrixB[87];
int sweepCount = 1e6;
time_t time1, time2, time3, time4;
time(&time1);
for(int count = 0;  count < sweepCount; ++count) {
    memcpy(matrixB, matrixB_ori, sizeof(double)*87);
    dtrsm("Right", "Upper", "No transpose", "Nunit", &MmatrixARows, &NmatrixBColumns, &alpha, matrixA, &ldm, matrixB, &ldm);
time(&time2);
std::cout<<" Before new 8 VSLStreamStatePtr time: "<<difftime(time2, time1)<<std::endl;
VSLStreamStatePtr                   ptr_[8];
for(int i = 0; i < 8; ++i) {
    vslNewStream(&ptr_, VSL_BRNG_MT2203 + i, 1);
time(&time3);
time(&time4);
std::cout<<"After new 8 VSLStreamStatePtr time: "<<difftime(time4, time3)<<std::endl;
jian_l_1
Hi, Fiona
Can you repeat the issue? Or need more detail info about lib verstion and cpu info?
Fiona Z. (Intel) wrote:
Hi jian,
Fiona
Zhen_Z_Intel
Hi Jian,
I can reproduce your problem, we are investigating, I will give your response soon.
Fiona
Gennady_F_Intel
jian_l_1
Hi,Gennay
I am glad to hear that.Thanks for your help.
Gennady_F_Intel
To mitigate the problem, we may recommend set MKL_DISABLE_FAST_MM=1 to disable our memory buffering. Please refer more details into MKL's User's Guide -  Managing Performance and Memory
jian_l_1
Hi, Gennady
I tried  set MKL_DISABLE_FAST_MM=1 , But it make dtrsm which before Create 8 VSLStreamStatePtr become as slow as after them.
My code is linked with google's tcmalloc, which can be found in gperftools-gperftools-2.5.
And add a unused map before the code can help repeat the issue, the map is original code is a static map.
#include <map>
#include <iostream>
#include <cstring>
class aaaValue
public:
    ~aaaValue()                                          { aaa(); }
private:
    void aaa() {
            if (val_.sval)
                free(val_.sval);
            val_.sval = 0;
private:
    union { int ival; double dval; char* sval; }    val_;
int main(int argc, const char* argv[])
    std::map<int, aaaValue> Map;
    double alpha=1;
    int ldm=29;
    double matrixB[87];
    int sweepCount = 1e5;
    time(&time1);
    time(&time2);
    time(&time3);
    time(&time4);
