DataFitting bug ?
Shigeo_Kobayashi
Pls run the program bellow,and confirm the difference between NY==1 and NY==2 case.
DFTaskPtr  task;
 // int NY = 2;
 int NY = 1;
 double x[] = {1,2, 3, 4,  5};
 double y[] = {0,2,-1,-0.5,0,-1,1,-2,-1.5,-1};
 int    NX  = sizeof(x)/sizeof(x[0]);
 int order  = 1;
 int dorder[] = { 0,0 };
 int ndorder = sizeof(dorder)/sizeof(dorder[0]);
 double coef[20];
 double xv   = 0.0;
 double yv[2];
 int status;
 status = dfdNewTask1D( &task,NX,x, DF_NON_UNIFORM_PARTITION, NY, y, DF_MATRIX_STORAGE_ROWS );
 status = dfdEditPPSpline1D(task, DF_PP_LINEAR, DF_PP_DEFAULT, DF_NO_BC , NULL, DF_NO_IC, NULL, coef, DF_NO_HINT);
 status = dfdConstruct1D( task, DF_PP_SPLINE, DF_METHOD_STD );
 for(int i=1;i<=NX;++i)
  xv = i;
  status = dfdInterpolate1D( task, DF_INTERP, DF_METHOD_PP, 1, &xv, DF_NON_UNIFORM_PARTITION, ndorder, dorder, NULL, yv, DF_MATRIX_STORAGE_ROWS, NULL );
  if(NY==2) printf("status = %d x=%g y=[%g,%g]\n",status,xv,yv[0],yv[1]);
  else      printf("status = %d x=%g y=[%g]\n",status,xv,yv[0]);
===== the results when NY=1 follow
status = 0 x=1 y=[0]
status = 0 x=2 y=[-1.5]    <= why not 2.0 ?
status = 0 x=3 y=[-1]
status = 0 x=4 y=[-0.5]
status = 0 x=5 y=[0]
===== the results when NY=2 follow
status = 0 x=1 y=[0,-1]
status = 0 x=2 y=[2,1]   <= Yes OK!
status = 0 x=3 y=[-1,-2]
status = 0 x=4 y=[-0.5,-1.5]
status = 0 x=5 y=[0,-1]
I got the results under  MKL V11.1.1 Product Build 20131010 for 32-bit application on Windows-7.
Gennady_F_Intel
thanks, we will check this case.
Gennady_F_Intel
yes, it looks a bug. the issue is escalated. we will update this thread in the case any news.
VictoriyaS_F_Intel
Hello Shigeo Kobayashi,
The test case you have provided reproduces a bug in MKL 11.1.1. dfdinterpolate1D function has an issue with processing small tasks when ny = 1 and nsite = 1, like in your example.
This issue was also revealed by our internal testing and the fix is planned for the next MKL 11.1 update. Currently you could use a workaround: Please use nsite = 2 and pass array of 2 elements as an array of interpolation sites to obtain correct results.
Shigeo_Kobayashi
Hi Victoriya,
Thank you for your comment. Yes,I wait for the next MKL release(this month?).
Gennady_F_Intel
yes
Gennady_F_Intel
Shigeo,
the fix of the problem you can find into 11.1 update2 released yesterday. Would you please check the issue with this update and let us know the results.
--Gennady
Shigeo_Kobayashi
Hi Gennady,
Yes, I downloaded 11.1 update2 and got correct results today.
Thank you and all MKL people !!
Gennady_F_Intel
another issue with performance, we are going to fix the next update. We will keep you updated with the status. Regards, Gennady
