Sstrange behavior MKL-FEAST
Sergio_S_
At the moment I am trying to implement a minimal working example of the <<dfeast_scsrgv>>   routine  in c++ of the FEAST package to solve the generalized eigenvalue problem Ax=lBx. The problem size is just 4x4 for testing  purposes
The first time I executed the program I got the error:
Info =3 that is a warning  "Size of the subspace m0 is too small (m0<m)".
thus I changed the value of M0 from 4 to 10 and tried again.
This time I the error was  "201" which means  "Problem with size of initial subspace m0 (m0≤0)"
this does not make any sense as M0 is positive.
I would appreciate any help on this.
[cpp]
#include <iostream>
#include<math.h>
#include<cmath>
#include<algorithm>
#include "mkl.h"
#include "mkl_solvers_ee.h"
using namespace std;
///////TEST MATRIX///////////////
  A=        |1  0  0  1|
        |0  2  1  0|
        |0  1  3  0|
        |1  0  0  4|
 B=         |1  0  0  0|
        |0  2  0  0|
        |0  0  3  0|
        |0  0  0  4|
PROBLEM Ax=lBx
int main(){
  MKL_INT fpm[128];
 //MATRIX SET UP
  double  AV[]={1,1,2,1,3,4};
  MKL_INT IA[]={1,3,5,6,7};
  MKL_INT JA[]={1,4,2,3,3,4};
  double  BV[]={1,2,3,4};
  MKL_INT IB[]={1,2,3,4,5};
  MKL_INT JB[]={1,2,3,4};
//SET UP EIGENSOLVER
//initialize parameters of FEAST algorithm
feastinit(fpm);
fpm[0]=1;
char UPLO= 'U';                            //uses the upper triangular part of the matrix
const MKL_INT N=4;                         //set problem size
double Emin=double(0.0), Emax=double(4);   // bounds of the igenvalues to be searched
MKL_INT M0=10;                              //initial guess
MKL_INT M=N;
MKL_INT info;                              //info of the outcome
double epsout;                             //contains relative error
MKL_INT loop;                              //ouput information
double E[10];                               //will contain the eigenvalues
double res;
double X[4*4];                             //initial subspace guess
 dfeast_scsrgv(&UPLO,&N,AV,IA,JA,BV,IB,JB,fpm,&epsout,&loop,&Emin,&Emax,&M0,E,X,&M,res,&info);
 cout<<"INFO="<<info<<endl;
  return 0;
[/cpp]
Gennady_F_Intel
hello,
this is the problem with documentation -- the initial guess for subspace dimension have to be like the follows  0<M0<=n
regards, Gennady
Gennady_F_Intel
hello,
regards, Gennady
Gennady_F_Intel
the documentation would be updated the next update of MKL ( 11.1 update 2 ) - we will let you know when it will happens,
Sergio_S_
Thank you, that solved the problem
Gennady_F_Intel
fyi -- the documentation has been updated into the version 11.1.2 released yesterday. You can check this update and let us know if any further issue/improvements we have to do with mkl's doc. regards, gennady.
