公告
Datafitting - Cubic Spline Boundary Conditions
Page__Chris
初学者
1,989 次查看
I would like to fit a cubic spline with the second derivatives at the end points linearly extrapolated from the two closest interior points. Is there a way to specify this type of boundary condition?
0 项奖励
1 回复
Pavel_D_Intel1
1,989 次查看
Hi Chris,
Intel MKL Data Fitting supports next types of boundary conditions for cubic splines:
  • not-a-knot
  • free end
  • periodic
  • user-definedе the first/second derivative at the left/right endpoint
You can set the specifically defined second derivatives at the endpoints as presented below:
MKL_INT bc_type;             // boundary conditions type
double bc[2];                      // array of boundary conditions
bc_type     = DF_BC_2ND_LEFT_DER | DF_BC_2ND_RIGHT_DER;
bc[0] = a;
bc[1] = b;
// Call dfdEditPPSpline1D( task, sorder, stype, bc_type, bc, ic_type, ic, scoeff, scoeffhint );
// Call dfdConstruct1D( task, DF_PP_SPLINE, DF_METHOD_STD );
Full code can be found in “dfdcubicsplineint2der.c” sample.
Feel free to ask more.
Pavel.
0 项奖励
回复
