Deal with huge matrix
chao_n_
I have written some codes with MKL library, but recently these codes do not work. They can be complied well and do not report any error when I run it. However, they did not work for some huge matrix operations. They keep running, but no results return. Here is an example code. When the variable nID exceed 31, the program will keep running forever.
#include <stdio.h>
#include <mkl.h>
int main(){
int nID=31;
int nSNP=33;
double *mMatrix = (double*) calloc(nID*nSNP,sizeof(double));
double *AGmatrix = (double*) calloc(nID*nID,sizeof(double));
    const CBLAS_LAYOUT Layout=CblasRowMajor;
    double alpha=1;
    double beta=0;
    cblas_dgemm (Layout, CblasTrans, CblasNoTrans, nID, nID, nSNP, alpha, mMatrix,
nID, mMatrix, nID, beta, AGmatrix, nID);
TimP
I suppose you had in mind some other compiler, but I tried to make a VS gui project with a recent Intel C++ for Intel64, hoping to run under debug. I had several issues with source code format and line terminators. I wasn't able to get the mkl include path working.  At command line, I was able to build, but I got immediate return to command prompt when running.
It doesn't appear that you should be approaching default limits for stack or (if in 32-bit mode) heap space, but you leave us guessing.
Ying_H_Intel
Hi Chao,
Could you please tell some details like the OS, 32bit or 64bit, how do you compile the mkl program?
for example, we run it in Red Hat Enterprise Linux Server release 6.3 on machine with16 core  . with command line
source /opt/intel/mkl/bin/mklvars.sh  intel64
$ g++ main.cpp -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lm
$ ./a.out
it just run fine.
Ying
Ying_H_Intel
Hi Chao,
You can
>export MKL_VERBOSE=1
>a.out
and let us know the result.
Ying
chao_n_
Ying H. (Intel) wrote:
Hi Chao,
You can
>a.out
Ying
I'm sorry. I still keep running.
[ningc@localhost sig]$ gcc -lmkl_intel_lp64 -lmkl_intel_thread -liomp5 -lmkl_core\
>  -lpthread -lm test.c
[ningc@localhost sig]$ export MKL_VERBOSE=1
[ningc@localhost sig]$ ./a.out
chao_n_
chao n. wrote:
Hi Chao,
You can
>a.out
Ying
I'm sorry. It still keep running.
When I set nID=31
MKL_VERBOSE Intel(R) MKL 11.3 Update 3 Product build 20160413 for Intel(R) 64 architecture Intel(R) Streaming SIMD Extensions 4.2 (Intel(R) SSE4.2) enabled processors, Lnx 2.00GHz lp64 intel_thread NMICDev:0
MKL_VERBOSE DGEMM(N,T,31,31,33,0x7fffdf46b9d0,0x20ed010,31,0x20ed010,31,0x7fffdf46b9d8,0x20ef010,31) 80.88ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:32 WDiv:HOST:+0.000
Ying_H_Intel
Hi
When set nID=32,32,33, my output is like below
[yhu5@snb04 mkl_issue]$ ./a.out
Error getting SCIF driver version
MKL_VERBOSE Intel(R) MKL 11.3 Update 3 Product build 20160413 for Intel(R) 64 architecture Intel(R) Streaming SIMD Extensions 4.2 (Intel(R) SSE4.2) enabled processors, Lnx 2.70GHz lp64 intel_thread NMICDev:0
MKL_VERBOSE DGEMM(N,T,32,32,33,0x7fffa3280650,0x165e010,32,0x165e010,32,0x7fffa3280658,0x1660120,32) 3.61ms CNR:SSE4_2 Dyn:1 FastMM:1 TID:0  NThr:16 WDiv:HOST:+0.000
The  notable places is maybe the machine type be "   Intel(R) Streaming SIMD Extensions 4.2 (Intel(R) SSE4.2) enabled processors. and thread number".
Do you have other machine to test the code?   and for thread number , how about if you
>export MKL_NUM_THREADS=1
>a.out?
Ying
chao_n_
Hi
When set export MKL_NUM_THREADS=1, it work well.
However, I can not set more than one threads. How can I solve the problem?
Hi
>a.out?
Ying
