7301 Discussions
Different answers between MKL and Netlib Lapack
ankur28
Hi Everyone,
I am getting different results between MKL and netlibs LAPACK implementation. I am solving a large constrained linear system (solving Ax=B subject to Cx=D, where D = vector of zeros, A is on the order of 60K X 30 and is block-diagonal).
The results that I get from netlib LAPACK are:
1.001544335038921
-0.000754480410948
-0.118852846248803
-0.002819465096284
0.998960344715003
0.750248126784616
The result from MKL is:
1.00029802322388
-0.00063318014145
-0.02181071229279
-0.00281071662903
0.99918329715729
0.67531794309616
I have posted the first six entries of the result to outline the difference. The matrices are the same in both the cases.
Following are the flags that I am using for icc:
CFLAGS = -ggdb -fp-model precise -align -Zp16 -O0
INCPATH = -I/opt/intel/ipp/5.3.2.068/em64t/include -I/opt/intel/mkl/10.0.2.018/include -I/usr/include/atlas -I/usr/local/include/opencv -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/inclu de/qt4/QtCore -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtGui -I/usr/include/qt4 -I.
The netlib answer is the correct answer in this case.
Any pointers to what might be causing this mystery difference?
-Ankur
Michael_C_Intel4
DearAnkur,
which LAPACK routines do you use to solve it?
Michael.
