7299 Discussions
Different function-signatures between some aliased LAPACK functions
DenizBahadir
Background information
In general, every LAPACK function has four names under which it can be called from C, which are all defined in header mkl_lapack.h:
An all uppercase version, an all lowercase version, an all uppercase version with a trailing underscore and an all lowercase version with a trailing underscore.
Besides these, there also exist similar 64-integer versions with all uppercase or all lowercase names that have "_64" appended.
Problem
I noticed, that some of these function tuples have different function signatures although they should just be aliases of each other, which leads to compiler errors due to non-matching parameter-types (when trying the different function aliases with the exact same type of parameters).
In particular, the following functions differ in their function signature compared to their aliases.
  • SGEJSV: Its second parameter "jobu" is missing the const keyword. Its alias functions all have a const parameter "jobu".
  • SGEJSV_64: Same error as for SGEJSV.
  • CLAQZ0: Its first three parameters "wants", "wantq" and "wantz" are of type const char* while its three alias functions define them as const MKL_INT*. According to the LAPACK documentation at netlib.org const char* seems to be correct. So the three alternatives are wrong.
  • CLAQZ0_64 / claqz0_64: Here the first three parameters are of type const MKL_INT64*. These should probably also be of type const char* instead!?
  • ZLAQZ0: The same comment as for CLAQZ0 applies here.
  • ZLAQZ0_64 / zlaqz0_64: The same comment as for CLAQZ0_64 / claqz0_64 applies here.
  • ZLAQZ1: The four parameters "a", "b", "q" and "z" are of type MKL_Complex8* while its three alias functions define them as MKL_Comples16*. According to the LAPACK documentation at netlib.org MKL_Complex16* seems to be correct. So the three alternatives are correct.
Additional information
I am seeing this problem with MKL 2022.1.0.
DenizBahadir
It seems as if this issue is fixed by MKL 2023.0.0.
Thank you!
ShanmukhS_Intel
Thank you for posting on Intel communities.
I noticed, that some of these function tuples have different function signatures although they should just be aliases of each other, which leads to compiler errors.
>> Could you please let us know what sort of compiler errors were faced by you?
Do you mean you are getting compiler errors (like type miss-match) when calling a function with it's alias name?
Shanmukh.SS
Shanmukh.SS
DenizBahadir
Exactly. (To be precise, these are warnings, but as I am treating warnings as errors, these are compiler errors for me.)
For example:
Assume, I have a wrapper-function around CLAQZ0 which is defined like this:
#include <mkl_lapack.h>
/* My_CLAQZ0 has the same signature as CLAQZ0! */
void My_CLAQZ0( const char* wants, const char* wantq, const char* wantz, const MKL_INT* n,
                const MKL_INT* ilo, const MKL_INT* ihi, MKL_Complex8* a, const MKL_INT* lda,
                MKL_Complex8* b, const MKL_INT* ldb, MKL_Complex8* alpha, MKL_Complex8* beta,
                MKL_Complex8* q, const MKL_INT* ldq, MKL_Complex8* z, const MKL_INT* ldz,
                MKL_Complex8* work, const MKL_INT* lwork, float* rwork, const MKL_INT* rec,
                MKL_INT* info)
    #if defined(WRAP_CLAQZ0)
        return CLAQZ0( wants, wantq, wantz, n,
                       ilo, ihi, a, lda,
                       b, ldb, alpha, beta,
                       q, ldq, z, ldz,
                       work, lwork, rwork, rec,
                       info );
    #elif defined(WRAP_claqz0)
        return claqz0( wants, wantq, wantz, n,
                       ilo, ihi, a, lda,
                       q, ldq, z, ldz,
                       info );
    #else
        #error "Either define WRAP_CLAQZ0 or WRAP_claqz0!"
    #endif
If you try to compile this with WRAP_CLAQZ0 defined everything compiles.
If, however, you try to compile this with WRAP_claqz0 defined, you will get errors as the following ones (which came from Clang 12):
$> clang-12 -Werror -Wall -c My_CLAQZ0.c -I /opt/intel/oneapi/mkl/2022.1.0/include -DWRAP_claqz0
My_CLAQZ0.c:18:24: error: incompatible pointer types passing 'const char *' to parameter of type 'const int *' [-Werror,-Wincompatible-pointer-types]
/opt/intel/oneapi/mkl/2022.1.0/include/mkl_lapack.h:11520:29: note: passing argument to parameter 'wants' here
void claqz0( const MKL_INT* wants, const MKL_INT* wantq, const MKL_INT* wantz, const MKL_INT* n,
My_CLAQZ0.c:18:31: error: incompatible pointer types passing 'const char *' to parameter of type 'const int *' [-Werror,-Wincompatible-pointer-types]
/opt/intel/oneapi/mkl/2022.1.0/include/mkl_lapack.h:11520:51: note: passing argument to parameter 'wantq' here
My_CLAQZ0.c:18:38: error: incompatible pointer types passing 'const char *' to parameter of type 'const int *' [-Werror,-Wincompatible-pointer-types]
/opt/intel/oneapi/mkl/2022.1.0/include/mkl_lapack.h:11520:73: note: passing argument to parameter 'wantz' here
3 errors generated.
ShanmukhS_Intel
Thank you for pointing out and sharing the findings.
We are working on your issue internally. We'll get back to you soon with an update.
Best Regards.
Shanmukh.SS
Gennady_F_Intel
the issues you reported here were escalated and would be fixed into one of the next releases/updates. The thread will keep updated.
DenizBahadir
Thank you!
