7242 Discussions
Different result of MKL FFT between version 11.1.067 and 11.1.054
paolo17
I've been using MKL 2D-FFT integrated in a Visual Studio 2005 with a Fortran Compiler version 11.1.067 wiith the following commands:
!For a matrix A(N1,N2)
L(1)=N1
L(2)=N2
! First time only:
Status = DftiCreateDescriptor( Desc_Handle, DFTI_DOUBLE, DFTI_COMPLEX, 2, L )
Status = DftiCommitDescriptor( Desc_Handle )
! For each Trasform:
status = DftiComputeForward ( desc_handle, A )
Now I've updated the Fortran Compiler to the version 11.1.067, but the results of the same case now is wrong. I checked the user guide but I didn't find any specific change about the commands to be used.
Thanks for help,
Paolo
Dmitry_B_Intel
Hi Paolo,
The two results may be different because inputs are different, amongother possible reasons.
If you feel the computation is incorrect, please submit an issue at http://premier.intel.com
Dima
