Direct/PARDISO solvers
kodanda
I have been using MKL' DSS interface to deal with a indefinite matrices in the solution of A*x = y.
(1) my first question is if PARDISO is efficient compared to DSS? the length of 'x' is 60,000.
(2)In every iteration, I have been preparing A in the CSR format before passing it to the MKL subroutines, then I create the handles, create the structure, factorize, solve and delete the handles. Since the shape of my matrix A is fixed during all iterations, can I do the creation of handles(dss_create), and structure creation(dss_define_structure) and reorder (dss_reorder) only once in the very begining of iterations and use only factorization and solution during every iteration?
thanks for any inputs...
kodanda
Todd_R_Intel
(1) Intel MKL has one direct sparse solver for which we provide two interfaces: the PARDISO interface and DSS interface. The efficiency should be the same.
(2) Yes. The first part of the DSS section of the reference manual has an image (Figure 8-2 in the reference manual) that refers to just such a case.
-Todd
kodanda
thanks a lot
- kodanda
