Does MKL affect the intrinsic operations?
Hongwei_Zhou
HI
I got very strange behavior of MKL. With MKL linked in my program, in the debug module I monitored the result for
one line of pure fortran code becomes NaN. Linked to source code of blas instead of MKL, the result of that line of fortran code is normal.
I am wondering how MKL infulence the behavior of the program even on the intrinsic operation like mulitplicaiton.
Hongwei_Zhou
Quoting - optistruct
HI
This behavior only happens on 32 bit RH Linux machine.
TimP
One possibility is that passing bad data to an MKL function could cause it to exceed array bounds and write garbage where you didn't expect it. Setting debug mode in your program doesn't set it in MKL.
Gennady_F_Intel
Quoting - tim18
Optistruct, probably tim is right, but for investigation the problem - can you get us the test case?
