ECCN of products
De_Coster__Maxime
Would it possible to know the ECCN of the following components :
  • Intel IPP Legacy in version 9
  • Intel MKL in version 2017.2
  • Intel openmp in version 17.0.2
Thanks a lot !
Moreover, is there any website where I could retrieve directly all the information ?
Maxime
Gennady_F_Intel
ECCN for IPP 9.x is 4D994.
Gennady_F_Intel
Maxime, are you are aware that all of these versions are no longer supported?
for the latest ones - please check this forum - https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/850219#
Gennady_F_Intel
and there is not one page with such info. Thanks for the idea, make sense to create the one place with this info....
De_Coster__Maxime
Ok thank you for the information ! And yes I knew, these are legacies code that I have to maintain. I believe that ECCN for new versions are still fine for older versions ?
Do you know if "Intel openmp" is part of IPP, or it is a complete different software with another ECCN ?
Gennady_F_Intel
the ECCN are differents for these versions. We need to check with the marketing persons who are responsible for these libs...
The Intel OpenMP runtime library is part of the Intel compiler and probably ( but I am not sure )  you need to have the ECCN numbers for this lib separately.
Gennady_F_Intel
here is the link to the intel c/c++ compiler forum - https://software.intel.com/en-us/forums/intel-c-compiler
Gennady_F_Intel
Gennady_F_Intel
MKL 2017 has the same ECCN number as IPP – 4D994.
De_Coster__Maxime
Ok Great ! Thank you for the answers.
