7303 Discussions
ERROR during symbolic factorization: -1. Even in runing the example code like pardiso_sym.c
kaihuang
My CMakeLists.text:
cmake_minimum_required(VERSION 3.17)
project(test)
set(CMAKE_CXX_STANDARD 14)
FIND_PACKAGE( OpenMP REQUIRED)
if(OPENMP_FOUND)
message("OPENMP FOUND")
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} ${OpenMP_C_FLAGS}")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${OpenMP_CXX_FLAGS}")
endif()
#set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -O0")
#set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -O0")
#set(CMAKE_BUILD_TYPE "Release" )
include_directories( "/usr/include/eigen3" )
include_directories(/opt/intel/oneapi/mkl/2023.1.0/include)
link_directories(/opt/intel/oneapi/mkl/2023.1.0/lib/intel64)
include_directories(/opt/intel/oneapi/compiler/2023.1.0/linux/include)
link_directories(/opt/intel/oneapi/compiler/2023.1.0/linux/lib/intel64)
include_directories(/home/chenkaihuang/sycl_workspace/llvm/build/install/include)
link_directories(/home/chenkaihuang/sycl_workspace/llvm/build/install/lib)
add_executable(test pardiso_sym.c)
target_link_libraries(test -Wl,--start-group /opt/intel/oneapi/mkl/2023.1.0/lib/intel64/libmkl_intel_ilp64.a /opt/intel/oneapi/mkl/2023.1.0/lib/intel64/libmkl_gnu_thread.a /opt/intel/oneapi/mkl/2023.1.0/lib/intel64/libmkl_core.a -Wl,--end-group -lgomp -lpthread -lm -ldl)
My pardiso_sym.c:
* Copyright 2004-2022 Intel Corporation.
* This software and the related documents are Intel copyrighted materials, and
* your use of them is governed by the express license under which they were
* provided to you (License). Unless the License provides otherwise, you may not
* use, modify, copy, publish, distribute, disclose or transmit this software or
* the related documents without Intel's prior written permission.
* This software and the related documents are provided as is, with no express
* or implied warranties, other than those that are expressly stated in the
* License.
* Content : Intel(R) oneAPI Math Kernel Library (oneMKL) PARDISO C example
/* Example program to show the use of the "PARDISO" routine */
/* on symmetric linear systems */
/* This program can be downloaded from the following site: */
/* www.pardiso-project.org */
/* (C) Olaf Schenk, Department of Computer Science, */
/* University of Basel, Switzerland. */
/* Email: [email protected] */
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include "mkl_pardiso.h"
#include "mkl_types.h"
// Define the format to printf MKL_INT values
#if !defined(MKL_ILP64)
#define IFORMAT "%i"
#else
#define IFORMAT "%lli"
#endif
int main (void)
/* Matrix data. */
MKL_INT n = 8;
MKL_INT ia[9] = { 1, 5, 8, 10, 12, 15, 17, 18, 19};
MKL_INT ja[18] =
{ 1, 3, 6, 7,
2, 3, 5,
3, 8,
4, 7,
5, 6, 7,
6, 8,
7,
8
double a[18] =
{ 7.0, 1.0, 2.0, 7.0,
-4.0, 8.0, 2.0,
1.0, 5.0,
7.0, 9.0,
5.0, 1.0, 5.0,
-1.0, 5.0,
11.0,
5.0
MKL_INT mtype = -2; /* Real symmetric matrix */
/* RHS and solution vectors. */
double b[8], x[8];
MKL_INT nrhs = 1; /* Number of right hand sides. */
/* Internal solver memory pointer pt, */
/* 32-bit: int pt[64]; 64-bit: long int pt[64] */
/* or void *pt[64] should be OK on both architectures */
void *pt[64];
/* Pardiso control parameters. */
MKL_INT iparm[64];
MKL_INT maxfct, mnum, phase, error, msglvl;
/* Auxiliary variables. */
MKL_INT i;
double ddum; /* Double dummy */
MKL_INT idum; /* Integer dummy. */
/* .. Setup Pardiso control parameters. */
for ( i = 0; i < 64; i++ )
iparm[i] = 0;
iparm[0] = 1; /* No solver default */
iparm[1] = 2; /* Fill-in reordering from METIS */
iparm[3] = 0; /* No iterative-direct algorithm */
iparm[4] = 0; /* No user fill-in reducing permutation */
iparm[5] = 0; /* Write solution into x */
iparm[6] = 0; /* Not in use */
iparm[7] = 2; /* Max numbers of iterative refinement steps */
iparm[8] = 0; /* Not in use */
iparm[9] = 13; /* Perturb the pivot elements with 1E-13 */
iparm[10] = 1; /* Use nonsymmetric permutation and scaling MPS */
iparm[11] = 0; /* Not in use */
iparm[12] = 0; /* Maximum weighted matching algorithm is switched-off (default for symmetric). Try iparm[12] = 1 in case of inappropriate accuracy */
iparm[13] = 0; /* Output: Number of perturbed pivots */
iparm[14] = 0; /* Not in use */
iparm[15] = 0; /* Not in use */
iparm[16] = 0; /* Not in use */
iparm[17] = -1; /* Output: Number of nonzeros in the factor LU */
iparm[18] = -1; /* Output: Mflops for LU factorization */
iparm[19] = 0; /* Output: Numbers of CG Iterations */
maxfct = 1; /* Maximum number of numerical factorizations. */
mnum = 1; /* Which factorization to use. */
msglvl = 1; /* Print statistical information in file */
error = 0; /* Initialize error flag */
/* .. Initialize the internal solver memory pointer. This is only */
/* necessary for the FIRST call of the PARDISO solver. */
pt[i] = 0;
/* .. Reordering and Symbolic Factorization. This step also allocates */
/* all memory that is necessary for the factorization. */
phase = 11;
PARDISO (pt, &maxfct, &mnum, &mtype, &phase,
&n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, &ddum, &ddum, &error);
if ( error != 0 )
printf ("\nERROR during symbolic factorization: " IFORMAT, error);
exit (1);
printf ("\nReordering completed ... ");
printf ("\nNumber of nonzeros in factors = " IFORMAT, iparm[17]);
printf ("\nNumber of factorization MFLOPS = " IFORMAT, iparm[18]);
/* .. Numerical factorization. */
phase = 22;
if ( error != 0 )
printf ("\nERROR during numerical factorization: " IFORMAT, error);
exit (2);
printf ("\nFactorization completed ... ");
/* .. Back substitution and iterative refinement. */
phase = 33;
iparm[7] = 2; /* Max numbers of iterative refinement steps. */
/* Set right hand side to one. */
for ( i = 0; i < n; i++ )
b[i] = 1;
&n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, b, x, &error);
if ( error != 0 )
printf ("\nERROR during solution: " IFORMAT, error);
exit (3);
printf ("\nSolve completed ... ");
printf ("\nThe solution of the system is: ");
printf ("\n x [" IFORMAT "] = % f", i, x[i]);
printf ("\n");
/* .. Termination and release of memory. */
phase = -1; /* Release internal memory. */
&n, &ddum, ia, ja, &idum, &nrhs,
return 0;
RESULT:
/home/chenkaihuang/programming/test_mkl/cmake-build-debug/test
Process finished with exit code 1
mecej4
To be consistent when you link against libmkl_intel_ilp64.a, you should have chosen preprocessor definitions/compiler options to make the integer variables in your MKL calls to be treated as 64 bit integers.
Alternatively, let the integer arguments be the default 32-bit integer type, and use libmkl_intel_lp64.a when linking.
mecej4
kaihuang
Thanks for the reply. Can I understand like I should set the integer to be 64bit under current linking. I'm not sure I understand you totally due to the word "libmkl_intel_lp64.a" in your last sentence. Guess it should be 32bit library? Thank you.
mecej4
In the context of choosing between the LP64 and ILP64 versions of MKL, the issue is whether integer arguments to MKL routines are 4-byte or 8-byte integers. In contrast, when we use phrases such as "32-bit library", we are distinguishing between 32-bit addresses and 64-bit addresses. Please read this article for more details.
VarshaS_Intel
Has the information provided earlier helped you?
Could you please let us know if you have any other queries?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Varsha
kaihuang
VarshaS_Intel
>>Solved by the first answer.
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Have a Good Day!
Thanks & Regards,
Varsha
