7303 Discussions
Eigenvalue and Eigenvector Example Problem Help
Ulysses
I've put together a quick program to figure out how to use the MKL library to calculate the eigenvalues and eigenvectors of a real symmetric matrix A. However, I get the following error message when compiling: "Error 1 error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_LAPACK]". Can anyone help find my mistake? Any help would be appreciated. I have attached the sample project.
-Uly
Here is the code just in case the zip file doesn't upload:
program MKL_SpectralDecomp
use mkl_lapack
implicit none
integer n, ldz,lwork,liwork,lda,iwork,info
integer apsize
parameter (n=3)
parameter (lwork=n**2+6*n+1)
parameter (liwork=5*n+3)
parameter (ldz=n)
parameter (iwork=liwork)
parameter (lda=n)
character jobz,uplo
double precision ap(n*(n+1)/2),work(iwork)
double precision w(n),z(ldz,n)
data ap /3.0,4.0,6.0,5.0,7.0,8.0/
external dspevd
!!set parameters:
jobz='V'
uplo='U'
call dspevd(jobz, uplo, n, ap, w, z, ldz, work,
+ lwork, iwork, liwork, info)
pause
end
mecej4
Since you use the Fortran-77 calling convention, you may obtain the interface to the MKL routine by inserting "include 'mkl.fi'" after the IMPLICIT NONE declaration. You have an incorrect declaration for the integer workspace IWORK(LIWORK). After you have added "include 'mkl.fi'", you need to remove the unneeded and inconsistent declaration of DSPEVD as EXTERNAL. Alternatively, use the much simpler Fortran 9X interface:
program MKL_SpectralDecomp use mkl95_lapack, only : SPEVD implicit none integer, parameter :: n=3 integer info double precision ap(n*(n+1)/2), w(n), z(n,n) data ap /3d0,4d0,6d0,5d0,7d0,8d0/ call spevd(ap, w, 'U', z, info) write(*,*)' Info from SPEVD: ',info write(*,*)w end
mecej4
Ulysses
Thank you mecej4! Seems I put that example together too quickly. With your help I was able to find the problems in the code example. -Uly
Ulysses
