7299 Discussions
Error : The CALL statement is invoking a function subprogram as a subroutine.
vahid_a_1
I am trying to learn to use MKL routines. I have written a simple code for calculating the jacobian matrix. However, it ends up with the below error:
The CALL statement is invoking a function subprogram as a subroutine. [DJACOBI]
Here is my code and I am compiling it with: ifort -mkl newton2.f90
INCLUDE '/home/vahid/intel/composer_xe_2015.3.187/mkl/include/mkl_rci.f90'
program newton2
    implicit none
    real*8, dimension(3) :: x
    real*8, dimension(3,3) :: fjac
    real*8 :: phi1,phi2,phi3
    integer :: i,m,n
    integer, parameter :: maxit=100
    real*8, parameter :: eps=0.0001
    INCLUDE '/home/vahid/intel/composer_xe_2015.3.187/mkl/include/mkl_rci.fi'
    external fcn
    x(1)=0
    x(2)=0
    x(3)=0
    n=3;m=3
    !Call fcn (m, n, x, f)
    call djacobi(fcn , n, m, fjac, x, eps)
    write(*,*) fjac
end program newton2
subroutine fcn (m, n, x, f)
    real*8, dimension(3) :: x,f
    phi1=0 ; phi2 = 0.1; phi3= 0.9;
    f(1) = 2*(800) *(x(1)-0.7)  - 2*(12000)*(x(2)-0.45);
    f(2) = 2*(12000)*(x(2)-0.45)- 2*(1200)*(x(3)-0.9)  ;
    f(3) = x(1)*phi1 + x(2)*phi2 + x(3)*phi3 - 0.42  ;
end subroutine fcn
mecej4
Please read the MKL documentation for "Nonlinear Optimization Solvers - Jacobian Matrix Calculation Routines". The proper invocation is
iret = djacobi(fcn , n, m, fjac, x, eps)
where iret is an integer status code. The include file mkl_rci.fi contains the interface of this routine, and your calling it as a subroutine is in error.
mecej4
vahid_a_1
Thanks @mesej4. Your comment solved the issue.
Now, I have updated the code accordingly and I am trying to finalize the code by writing a simple newton-raphson solver for a system of nonlinear equations. I always have difficulty in the codes which use "interface".
Here is the updated code. I would like to pass f values from the fcn "subroutine" to the main program and perform a "matmul" operation. However, the elements of array "f" are zero and no information passes through the subroutine to the main program.
program newton2
    implicit none
    integer :: i,m,n
    !! ***** djacobi variables ******
    integer :: res
    !! ***** dgetri variables ******
    integer :: lda,lwork,info
    integer, dimension(3) :: ipiv
    real*8 :: work(3)
    !INCLUDE '/home/vahid/intel/composer_xe_2015.3.187/mkl/include/mkl_rci.fi'
    INCLUDE 'mkl_rci.fi'
    INTERFACE fcn
        SUBROUTINE fcn
            REAL*8, DIMENSION(3) :: x
            real*8, dimension(3) :: f
        END SUBROUTINE fcn
    END INTERFACE
    !! ************* Input arguments
    x(1)=0 ; x(2)=0 ; x(3)=0
    n=3;m=3;lda = 3;
    !! ************* Jacobi matrix of the user's objective function using the central difference
    res = djacobi(fcn , n, m, fjac, x, eps)
    write(*,*) fjac
    write(*,*) fjac(2,1)
    !! ************* The LU factorization of a general m-by-n matrix.
    ipiv = max(1,n)
    call dgetrf( m, n, fjac, lda, ipiv, info )
    write(*,*) fjac
    write(*,*) info
    !! ************* The inverse inv(A) of a general matrix A.
    lwork=3*1000
    call dgetri( n, fjac, lda, ipiv, work, lwork, info )
    write(*,*) fjac
    write(*,*) info
    !DO i=1,maxit
    write(*,*) x
    write(*,*) f
    write(*,*) matmul(fjac,f)
    x = x - matmul(fjac,f)
    write(*,*) x
end program newton2
    real*8, dimension(3), intent(out) :: f
    phi1=0.0 ; phi2 = 0.1D0; phi3= 0.9D0;
    return
end subroutine fcn
mecej4
The include file 'mkl_rci.fi' provides the interfaces needed, so you need not provide one for fcn again. Here is a sketch of what you need:
do iter = 1,maxit
   call fcn(...)  ! to compute f() at the current x()  <<=== you left this out in your code
   call djacobi(...)  ! to compute fjac() at the current x()
   call dgesv()   ! to solve for the Newton Raphson correction dx = J-1f
   compute ||dx|| or ||f||, decide whether to terminate iterations
   x = x - dx
end do
If your objective is just to obtain the solution, all that you have to do is to take the example code ex_nlsqp.f, which is included in the MKL installation, change m and n, put in your functions, build and run.
vahid_a_1
Dear mecej4,
My objective is to learn to use Intel MKL whenever I need it. Thanks for the suggestions. Everything works now and it solves my main equations. However, I have another question for you. Why using intel MKL makes the code very slow?! I mean very slow...
To b more precise,  I am solving a PDE and at each iteration, the code calls newton-raphson solver to solve a system of nonlinear equations.
I have two implementation of the code now. Iwhere in the 1st one, the newton-raphson solver is written by myslef and the inverse of jacobian is calculated analytically and just placed in the code manually. However, in the 2nd implementation, I have modified the newton-raphson solver by your help and used the MKL routines to do everything in Fortran. (calculating the jacobian and its inverse)
The 2nd implementation is very slow. The ratio of simulation time for 2 million iterations is : (6minutes / ~3 hours) ---> (my newton-raphson/Intel MKL)
Both of the implementations work in serial mode.
do iter = 1,maxit
   x = x - dx
end do
mecej4
What is the size of the system of nonlinear equations? If it is large, calculating the Jacobian by calling DJacobi() will be very wasteful and expensive. At the very least, use a variation of Newton-Raphson in which the Jacobian is updated or calculated sparingly, instead of calculating every time -- straight Newton-Raphson is not a good method for solving large systems of nonlinear equations.
To solve a linear system A x = b, it is not a good approach to form inv(A) and multiply b with that. Instead, call a routine such as DGESV, which will solve the equations twice as fast.
