7297 Discusiones
Error in debugging example file 'cg_mrhs_precond.f'
Zhanghong_T_
Novato
1.309 Vistas
Hi all,
I have problem to debug the example file 'cg_mrhs_precond.f'. I set a breakpoint after the statement
ELSEIF (RCI_REQUEST .EQ. 3)THEN
However, the program directly run to the last line without pausing at the breakpoint. Furthermore, I checked the solution X and found the are all ZERO.
Could any one help me to solve the problem? Or is there any bug?
Zhanghong Tang
0 kudos
1 Responder
Sergey_G_Intel
Empleados
1.309 Vistas
Dear Zhanghong Tang,
Please try to compile the example 'cg_mrhs_precond.f' with preprocessor. It would be -fpp compiler option on Linux, /Qfpp on Windows, or marked field "Preprocess Source File" in Visual Studio (if you have Intel Fortran Compiler installed).
If this does not help to resolve your problem, please provide more information on the problem: OS, compiler, computer. It would be even greater if you can provide a test case that fails.
Responder
