Error using oneMKL mkl_sparse_d_mv function
zhang__boyuan
I'm trying to use the fgmres algorithm to solver sparse linear equations. I modified the example code in fgmres_no_precon.c a little bit to accomodate the input data in my project. Everything is fine until it comes to the mkl_sparse_d_mv function in the following command:
mkl_sparse_d_mv(transA, 1.0, csrA, descrA, expected_solution, 0.0, rhs);
The error message I got is:
Unhandled exception at 0x00007FFF0A084ED9 (KernelBase.dll) in Aphi_MatrixEq_IterativeSolver.exe: 0xC06D007E: Module not found (parameters: 0x000000570B263510).
I use Microsoft Visual Studio 2019 as compiler, and then install Intel oneAPI and linked the MKL to VS automatically. Besides Intel MKL, I included EIGEN library in my project as well.
I don't have a strong computer science background. Does this error message mean the KernelBase.dll file has been corrupted in my Windows 10? I took a look at the KernelBase.dll file in my system and it looks it was updated at July 14th, 2021. I updated my Windows 10 around that time.
Any advice on how I should fix this problem would be greatly appreciated.
Best,
Boyuan
zhang__boyuan
Hi Rajesh,
Thanks for asking. Yes I think I solved it, and I made a stupid mistake which caused this problem. I changed the Intel oneAPI setting from Parallel to Sequential, and the fgmres example works well now.
I would like to thank everyone who replied here and tried to offer help.
Boyuan
mecej4
We should go poking into the guts of system DLLs only as a last resort.
You stated that your code is a modification of an MKL example code. Post the modified code as an attachment or a link to a cloud service where you have placed the file(s). If the program reads data from a file or the console, please provide the data.
zhang__boyuan
Thanks for the reply. I tried to compile and run the original example fgmres_no_precon.c by copying the code into a new project. The same error was reported when the
sentence was excuted.
I'm attaching a screenshot about the error message and a 'No Symbol Loaded' page.
Thanks again,
Boyuan
Kirill_V_Intel
Hi Boyuan,
Please have a look at a similar question asked a year ago at Microsoft support service:
https://social.msdn.microsoft.com/Forums/vstudio/en-US/617a5e4d-53f7-4c35-9d05-c5fb12162676/exception-thrown-at-0x75e14192-kernelbasedll-module-not-found?forum=visualstudiogeneral
One of the last replies there suggests that the issue is that Visual Studio cannot find DLLs (of MKL). So, please check the folders where you have MKL, that DLLs are there and check where the VS is trying to look for DLLs. If copying all DLLs of MKL into your project directory helps, then it is definitely an issue with the search paths for DLLs.
Best,
Kirill
MRajesh_intel
Can you please update whether your issue has been resolved or not?
Rajesh.
zhang__boyuan
Hi Rajesh,
Boyuan
MRajesh_intel
Since your issue has been resolved can we close this thread?
Rajesh.
zhang__boyuan
Sure, thanks again for the kind help!
Boyuan
MRajesh_intel
Thanks for the confirmation. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Rajesh.
