FFT and MKL Problems
JohnNichols
Honored Contributor I
Dear Intel:
I am using the PREVIEW Intel Fortran and the MKL.
I enclose a complete program I have just got started on -- the program does not return from the call to FFT().
I include the LIST.TXT which lists all of the set command -- I cannot see where the mklvars.bat has worked.  I can only compile the FFT program if I stick the MKL F90 file into the directory and add it into the VS Solution.
I realize this is probably something simple, but all my other MKL programs compile and run: Pardiso and FEAST without these steps.
John
Ying_H_Intel
Hi John,
I guess it is same issue with https://software.intel.com/en-us/node/635264, right?
Ying
JohnNichols
Yes and it is solved thank you.
