FFT with oneMKL
MGRAV
I am currently trying the new oneAPI,
I have the impression that if we pass the simple level of arithmetic computation, examples are coming rare.
Would be possible to have a simple example of FFT computation using oneMKL, with the associate compile line for the devCloud ?
Best,
Mathieu
Khang_N_Intel
Hi Mathieu,
There are oneMKL FFT examples that come with the Intel(R) oneAPI Base Toolkit
Assuming that you install the toolkit for linux* under the folder /opt/intel.  The oneMKL examples will be in the folder: /opt/intel/inteloneapi/mkl/latest/examples.
The oneMKL DPC++ examples will be in the compressed file examples_sycl.tgz
After un-compressing that file, you will find FFT examples in the fold ...sycl/dft
Use the command make to compile and link the examples.  Typing only the command make will show you many options on how to compile and link the examples.  You can capture the screen or redirect the output to a file to see how the examples are compiled and linked.
To get started on devcloud, please follow this link:
https://devcloud.intel.com/datacenter/learn/getting-started/
Hope this helps!
Khang
Khang_N_Intel
Hi Mathieu,
Hope this helps!
Khang
Gennady_F_Intel
please also check how to link with MKL 2021 beta bt using the MKL Linker Adviser.  Selecting Intel Product as oneAPI MKL 2021.1-beta and Adviser will give you the link line,
MGRAV
Thanks both, I find the examples !
And I was able to compile.
Mathieu
Khang_N_Intel
Hi Mathieu,
That's great!
If you have any other questions or suggestions please do not hesitate to contact me.
Khang
